Rattle: how should my tailpipe be attached to the muffler?
MGQ
PostPosted: Tue Jun 15, 2004 10:21 am    Post subject: Rattle: how should my tailpipe be attached to the muffler? Reply with quote
I've been getting a bad rattle sometimes, and my car sounds less sporty. Looking underneath I see that where the exhaust pipe goes into the muffler, on the front side, it's totally loose, and the muffler swings on it's hangar and rattles.
should there be a part there, holding the muffler on or should I just weld the two together?
Brown 78 924. 4 speed, AC, Sunroof
5150
PostPosted: Tue Jun 15, 2004 5:01 pm    Post subject: Reply with quote
Dunno if you guys have the same system layout as the UK.. but here my '78 system is as follows:
Front pipe joins to center box via a pair of 3-bolt plates (one plate on the front pipe, one on the box nipping together).
Center box joins to a single large (2 box) rear section via a normal compression joint, ie one pipe slides into the other and is clamped in place.
Mars Red '78 Euro 924 n/a
There are two kinds of pedestrians: the quick and the dead.
MGQ
PostPosted: Wed Jun 16, 2004 10:23 am    Post subject: Reply with quote
So the front part of your muffler is clamped on? I'm talking about the part directly above the left axle.
5150
PostPosted: Wed Jun 16, 2004 4:37 pm    Post subject: Reply with quote
Sounds either like a different set-up for you guys, or your rear section is bust... from the front box (under the front of the car) there is only one complete section all the way to the back - has the rear "muffler" and a smaller box combined in one huge section - no joins anywhere at the back...
MGQ
PostPosted: Wed Jun 16, 2004 10:25 pm    Post subject: Reply with quote
Thanks. If it's all supposed to be one big peice. I'll just weld it back together. the seam where the pipe enters the muffler must have broken.
