-nick
Posted: Fri Oct 13, 2006 3:42 am Post subject: |
If you can see the fumes, then it's probably too much. This is at idle speed too??
A leak-down will tell you what shape your rings are in. Broken top compression rings are fairly common on stock 931's with some mileage on them. _________________ 1980 931S
1991 964 C4 Cabriolet |
