Posted: Wed Oct 11, 2006 6:11 am Post subject: Oil Pressure Gauge Repair? |
My OPG is bad, but has shown signs of life (flickers from accurate reading to pegged).
Anyone ever had any success reconditioning these things? _________________ Toofah King Bad
NEMESIS
Joined: 29 Jul 2006 Posts: 296 Location: BamaLamaDingGone, of course!
Posted: Wed Oct 11, 2006 6:31 am Post subject: |
| Sure it's the gauge and not the sender? |
Posted: Wed Oct 11, 2006 6:34 am Post subject: |
Indeed, after contorting myself in ways I never thought possible in order to replace the old one! _________________ Toofah King Bad
NEMESIS
Posted: Wed Oct 11, 2006 7:50 am Post subject: |
Thanks for the link, but I already have a spare. . .I sort of want to revive the green matching one. _________________ Toofah King Bad
-nick
Posted: Fri Oct 13, 2006 3:44 am Post subject: |
Does the spare gauge read correctly? _________________ 1980 931S
1991 964 C4 Cabriolet |
Posted: Fri Oct 13, 2006 5:36 am Post subject: |
It doesn't, it is calibrated for a different range. _________________ Toofah King Bad
-nick
Posted: Fri Oct 13, 2006 7:21 am Post subject: |
All the gauges (in psi / bar / kpa) use the same sender as far as I know. So your extra should work if you have a bad stock gauge.
Sounds like time to pull out the multimeter and start tracking down the wires from the oil pressure sender to the gauge. _________________ 1980 931S
Posted: Fri Oct 13, 2006 7:38 am Post subject: |
Nah, the sender and gauge have to match. The 931 sender and gauge are 0-150 PSI, and my spare only goes to 80.
Posted: Fri Oct 13, 2006 10:50 am Post subject: |
Try using an analog volt meter instead of your gauge and see if the needle behaves the same. _________________ White 87 924S "Ghost"
Posted: Fri Oct 13, 2006 12:27 pm Post subject: |
It's the gauge. With the ignition on, it pegs, but my spare reads zero. _________________ Toofah King Bad
