procon
Posted: Sat May 22, 2004 1:46 pm Post subject: 924 water pump question |
Just replaced the water pump on my 1980 924 as per instructions in the Haynes manual, with no problem.
However, when I go to start it & bleed the cooling system it won't run.
The engine turns over, fires, runs for a couple of seconds & dies. It does this twice & the won't fire up again for 5 mins. or so.
Ran like a champ before the change!
Any suggestions as I'm totally baffled by this???
Thanks in advance
Jay |
CMXXXI
Posted: Sun May 23, 2004 2:18 am Post subject: |
Did you by chance mess with the timing belt when you swapped out the pump? If you did, it is possible you changed the valve timing on reassembly. If not, it's back to the basics - Fuel, spark, air _________________ '79 Eurospec 931 |
procon
Posted: Sun May 23, 2004 2:39 am Post subject: It's all good! |
Just had to pull the thermostat & fill the top of the cooling system, duh.
Thanks for the help!!
JC |
Diesel
Joined: 03 Nov 2002 Posts: 1061 Location: Ellington,CT
Posted: Sun May 23, 2004 2:57 am Post subject: |
That won't stop it from starting. _________________ Dan Flanagan--2002 VW Jetta TDI, 83 Mercedes 300D,83 Mercedes Euro-240D |
procon
Posted: Sun May 23, 2004 7:07 am Post subject: |
Look, I'm no expert, but would'nt crank before, did after.
Beleive it or not. |
