Wheel spacer removal?
FAUST
PostPosted: Mon May 10, 2004 12:19 am    Post subject: Wheel spacer removal? Reply with quote
I scored a set of 16" disc wheels, 6X16, (928 look alikes) in a junkyard. The wheel spaces used in the rear just rest on the extended lugs and came right off. The front spacers are fixed and my manual doesn't even mention them. How do I get them off?
PostPosted: Mon May 10, 2004 12:45 am    Post subject: Reply with quote
There's bolts between the lug bolts.
PostPosted: Mon May 10, 2004 6:32 am    Post subject: Reply with quote
You're talking five bolt "trashcan lid" wheels, right?
The 924 version is a 16 X 6, but the 928 version is 7s, with more offset.
The 924 version did not use spacers in the front, and with spacers would probably stick out farther than the fenders.
The 928 version, when installed at the front, because of the extra offset might need spacers to clear the springs.
John Brown
PostPosted: Mon May 10, 2004 11:25 pm    Post subject: Reply with quote
The 928 version fits. It's tight but it fits. Tire specific clearance issues possible and negative camber is limited. Street settings are fine.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
