pyromjm
Joined: 26 Sep 2003 Posts: 154 Location: Cupertino, CA USA
Posted: Tue Apr 27, 2004 8:01 am Post subject: Distrubutor wires HELP! |
one of the wires that run into the distributor (the grey one) has been cut by the part that spins around that the rotor connects to. The reason this happened is because the black plastic clip that holds the wires in places was broken by the previous owner and it was taped in place with electrical taped. I think i might be able to fix the wire? but where would i get a new clip? Ive looked online and i can only find caps or rotors to buy!, whats the best thing i can do to get this problem fixed?
-Mike |
leadfoot
Posted: Tue Apr 27, 2004 8:21 am Post subject: |
ouch....
Without having it in front of me i can only suggest mabye another model car distributor clip from a wreckers, trying a vw or audi parts supplier, or fashioning one from something like the airbox uses.
leadfoot |
pyromjm
Posted: Tue Apr 27, 2004 8:24 am Post subject: |
| Hm yea i guess ill see if i can find a porsche pick 'n' pull around here, i live in the california bay area, anyone know of one around here? |
D Hook
Posted: Tue Apr 27, 2004 11:00 am Post subject: |
| What year is your car? |
Fuzzbeaner
Posted: Tue Apr 27, 2004 11:42 am Post subject: |
I'm not quite sure what you're talking about (not good enough with cars I guess) but I'm just tearing down the internal combustion part of my car.
If you need something from the distributer area just let me know.
-Jeff _________________ A Ravaged '77 924 (Electric Conversion in Progress) |
pyromjm
Posted: Tue Apr 27, 2004 12:28 pm Post subject: |
Sorry, its a 1982 n/a. I suppose i need a whole new distributor? i dont know if that clip comes off? or comes separately? i dont really know a lot about this area either. maybe i can get a picture of it or somthing
-Mike |
augidog
Posted: Tue Apr 27, 2004 12:46 pm Post subject: |
Are you talking about the ground wire on the metal insulating cap?
I have some old clips off a dismantled distributor if you need one. _________________ 1978 924 95 mile daily driver.
jl924t
Joined: 03 Nov 2002 Posts: 214 Location: Surrey, BC Canada
Posted: Tue Apr 27, 2004 1:28 pm Post subject: |
I cut off my plastic clip (mine is green and is actually 2 wires, the centre wire and the sheilding)and replaced it with 2 small female spade tip connectors and plugged them into the distributor. It's been working fine since last September. The spade tip connectors are the small ones that are used for speaker connections. I used the same connectors for my thermal time switch. I have a 1980 turbo. _________________ 1980 924 turbo |
1982Porsche924
Joined: 14 Nov 2002 Posts: 679 Location: Cupertino, CA
Posted: Tue Apr 27, 2004 2:01 pm Post subject: |
Whoops, I remember when i broke that part. I intended to replace it before i sold it, but it kinda got put off, sorry about that. Contact PartsHeaven in Hayward, they're an all Porsche junkyard. You don't pull your own part, and they charge a pretty hefty premium. Look at evilbay as well, make sure you get an 81-82 distributor, otherwise it won't work. _________________ 1979 Porsche 924 "S"
Engine: Euro pistons, Light Flywheel, Weber TB, Bursch Header, Cam Wheel
Suspension: Front coil-overs, adj sways, Solid bush. Thicker tors. bars, 5-bolt, BBS rims
Body: Fiberglass widebody kit, 931 Nose |
pyromjm
Posted: Tue Apr 27, 2004 2:27 pm Post subject: |
Heres a picture of the problem. The white wire is what i used to splice the broken wire to get myself home, the tape is holding them all down under the rotor so they dont get chopped up again.
-Mike |
pyromjm
Posted: Wed Apr 28, 2004 6:26 am Post subject: |
| So does anybody know hwere i can get a new one of these things with the wires? |
Roger
Joined: 06 Jan 2003 Posts: 1235 Location: Cordova, TN
Posted: Wed Apr 28, 2004 10:03 am Post subject: |
I have a spare off an 81 _________________ 1981 924 NA
still can't help but smile when you see one tumble down the stairs. |
pyromjm
Posted: Wed Apr 28, 2004 12:31 pm Post subject: |
if i could buy it from you i would be your best friend.
-Mike |
1982Porsche924
Posted: Wed Apr 28, 2004 12:40 pm Post subject: |
Hey Mike, you do the valve adjustment yet? If not, I could help you out this week. _________________ 1979 Porsche 924 "S"
pyromjm
Posted: Wed Apr 28, 2004 1:24 pm Post subject: |
Hey d-man, i didnt do it yet, i found that socket you were talking about! it would be cool to do that sometime this week
-Mike |
