Sunroof Question
mosborn
PostPosted: Sat Apr 10, 2004 2:55 pm    Post subject: Sunroof Question Reply with quote
When I purchased my 924S, the previous owner told me I needed to replace the relays in the rear trunk of the car. I've done this, however, the sunroof will only go up/down in one direction.
The previous owner rigged a "Y" cable that when it's put in the connector one way will enable the sunroof to raise and the other way lower. One possibility is the switch on the center console as to activate the sunroof (depending on the position of the "Y" connector) I have to press the "up" part of the switch.
One other question on this topic, does the sunroof "Lock down" when activated to lower? When I do this to the arm stops, the arms retract into the roof and this allows me to remove the panel.
Help?
Mike Osborn
PostPosted: Sat Apr 10, 2004 10:36 pm    Post subject: Reply with quote
Here's the place to find the best write up I've seen on our sunroofs:
http://www.clarks-garage.com/
Click on the "Garage Shop Manual" on the upper left, then scroll down to the sunroof section.
