mikl1976
Posted: Sun Mar 14, 2004 6:48 pm Post subject: Supercharged 924S |
Just curious if anyone else out there has a supercharged 924S?
It seems that everyone is surprised that i had that installed instead of a turbo or keeping it NA. |
sparky
Posted: Sun Mar 14, 2004 10:36 pm Post subject: |
Hi mik,
what were your reasons for choosing a supercharger?
also how much did it cost and details on parts would be appriciated..
as would pics!!!
thanks
SparkY _________________ When the checkered flag drops... The Bull$hit Stops
1976 Euro 924 (The 945) - Full 951 Brakes/Suspension
1998 Boxster with goodies
2002 3.0 Xtype 4wd sport |
samivaan
Posted: Sun Mar 14, 2004 11:55 pm Post subject: |
Hi Mikl1976,
what is your car compression ratio, and how high boost you use? |
Posted: Mon Mar 15, 2004 1:33 am Post subject: |
Form Mikl1976's website:
Here is one of the first things I have done with my car. I have purchased Huntley Racing's Super Charger. ($5000.00) It was a long and involved process, but I believe it was well worth it. they replaced all the vacuum lines, installed a mass air intake system, replaced the fuel injectors. But most important of all to me is this system allows me to keep my existing A/C. With the A/C off it has a much better pick up than stock. When the A/C is on it does take a little bit of the power away but it still has plenty to go around.
New
Horsepower: 210 Hp @ 5000
Torque: 210 lb. @ 3000 |
mikl1976
Posted: Mon Mar 15, 2004 3:23 am Post subject: |
well.. there is the picture of it.. thanks paul..
sparky.. i chose that because i wanted to increase the power significantly at a reasonable amount of cost. it cost $5000 in parts from Huntley Racing. I tried to go back to their website.. but it is down right now.. i dont know why that is.. if anyone is interested there number is 619-448-3800 unlessed they moved... if anyone gets a hold of them let me know.. there are a few other things i wanted to get from them..
samivaan - i dont have any gauges to determine the compression ratio.. and i forgot to ask the guys that put it on. later on i will get those numbers when i have more time.. right now there is not that much time with work. |
Manning
Joined: 29 Feb 2004 Posts: 151 Location: Akron O-Hi-O
Posted: Mon Mar 15, 2004 4:16 am Post subject: |
Rumor has it that the reason their website is down is because for all intents and purposes they are out of business. Probably why Derrick's Zebra 951 race car has been up on Ebay several times over the past few weeks. Anybody else know anything about that? _________________ Michael Manning
1988 924S Undergoing weight loss program |
Manning
Posted: Mon Mar 15, 2004 4:23 am Post subject: |
Mike, if they didn't do anything internally to the engine then you are running stock compression ratio. I am pretty sure you're not going to be able to hook a gauge up to you car and determine that. You actually have to pull the head and measure cylinder volume, combustion chamber volume of the head, etc. and plug those numbers into a formula to figure compression ratio.
Likely you're running stock compression ratio of 9.7:1 with light boost pressure. I am pretty sure that is what Huntley's plan was for at least their stage one system. _________________ Michael Manning
mikl1976
Posted: Mon Mar 15, 2004 5:21 am Post subject: |
they didnt do anything to the engine internally.. so yeah they would be stock compression ratio...
damn.. i didnt reallize that.. wonder what happened... they seemed to have a fair amount of buisness when i was there..
i wonder what happened.. |
Manning
Posted: Mon Mar 15, 2004 6:14 am Post subject: |
I don't really know what happened to them. I know there have been a lot of nasty posts about Huntley on Rennlist in the past, mostly regarding cheesy products and bad customer service, but that could just be bad feeling from a few people getting a lot of public air time. Kind of like how John Anderson has decided to not post on Rennlist any longer because there were so many posts about what a wanker he supposedly is (I don't know or care whether he is or not). Again, it is only a rumor going around and I can't say I have read anything from Derrick to confirm it.
I already recommended to you that you will want to consider some suspension and brake upgrades soon. I suggest if nothing has been done internally to your stock 79K mile motor that you (1) take it easy on the motor and (2) consider having an experienced shop inspect and freshen it up a bit. Things like bearing, seals and head gasket, you know what I mean? Adding boost is only going to accelerate the process of wearing those items out. _________________ Michael Manning
mikl1976
Posted: Mon Mar 15, 2004 6:22 am Post subject: |
i am taking it easy untill i get the money to have the engine reworked..
but one step at a time... |
Posted: Mon Mar 15, 2004 7:01 am Post subject: |
| That looks like a custom made intercooler, do you have a hood scoop? |
mikl1976
Posted: Mon Mar 15, 2004 7:04 am Post subject: |
| that is not a intercooler.. its the new manifold .. no hood scoop yet |
simsport
Joined: 06 Nov 2002 Posts: 573 Location: UK Warrington
Posted: Thu Mar 18, 2004 11:25 am Post subject: Blower |
Hi there
Which model eaton blower is it and what power is it making?
Cheers
Simon _________________ Blown is always best! |
mikl1976
