Crankshaft
BillA
PostPosted: Mon Jul 03, 2006 11:29 am    Post subject: Crankshaft Reply with quote
I cannot get the old needle bearing out of the crankshaft, it's in their pretty good! has anyone run across this before?
Bill
Raceboy
PostPosted: Mon Jul 03, 2006 5:16 pm    Post subject: Reply with quote
Yew, couple of times.
If special puller doesn't work, you'll probably have to dremel it out.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
-nick
PostPosted: Tue Jul 04, 2006 2:39 am    Post subject: Reply with quote
Pilot bearing puller + slide hammer is the way to go. Autozone has them for free with their "borrow a tool" thing. You just lay down a deposit while you borrow it.
nick
PostPosted: Tue Jul 04, 2006 11:05 am    Post subject: Reply with quote
I am guessing that you are just trying to remove the bearing?
might be easier to use a bolt and remove the housing from the crank first.
cannot remember the size or threadpitch of bolt needed to remove the housing though.
3 928s,
