82 931 Steering rack question
Dave951M
PostPosted: Mon Mar 15, 2004 12:36 am    Post subject: 82 931 Steering rack question Reply with quote
Is the steering rack on the 82 931 (with 5 bolt suspension) the same as the rack on the 83 944?
Dave951M
86 951 Guards Red (Gone but not Forgotten!)
82 931 Guards Red (under construction)
dpw928
PostPosted: Mon Mar 15, 2004 4:44 am    Post subject: Reply with quote
Dave,
The parts and tech manual lists them as different part numbers.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
Dave951M
PostPosted: Mon Mar 15, 2004 5:27 am    Post subject: Reply with quote
True, but will they interchange. I've found several instances of the number being different from another part that will interchange from Audi/VW. Since my ps rack in my 951 may be damaged from an accident, I was thinking of using one from an 82 931. That year is supposed to have the same suspension as the 83 944, and if that's true, then the rack should work with minor modification.
Dave951M
924guy
PostPosted: Mon Mar 15, 2004 6:05 am    Post subject: Reply with quote
id strongly suggest you verify this, but im 99% sure they will interchange, i believe the only difference is the turning ratio, as the 931 has "quicker" steering... I seem to remember someone using a 931 as a drop in replacment on an early 44' for track duty... double check this though, my memory might be off a bit... maybe try a search on rennlist, or the old boards here...its in one of those places i probably saw it....
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
John Brown
PostPosted: Tue Mar 16, 2004 11:01 am    Post subject: Reply with quote
You're talking power steering vs manual. I think an early 944 manual rack will interchange; but not with the power rack.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
PostPosted: Tue Mar 16, 2004 11:03 am    Post subject: Reply with quote
physically I believe it will bolt up and be able to connect (may also need the shaft that runs from steering column to rack with 2 U joints) and the tie rods should connect, however you would also need to eliminate the power steering pump and hoses from the car
3 928s,
924guy
PostPosted: Tue Mar 16, 2004 11:48 am    Post subject: Reply with quote
wasnt the 1983 944 manual steering? i seem to remember something about that..
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
PostPosted: Tue Mar 16, 2004 11:50 am    Post subject: Reply with quote
that is correct
3 928s,
Zuffen
PostPosted: Sat Mar 20, 2004 1:00 pm    Post subject: Reply with quote
won't interchange...why you ask
steel crossmember on the 924 and 931
aluminum crossmember on the 924S and 944
rack mounts with bolt hole brackets welded to rack on the steel member
rack mounts with aluminum clamp saddles (not fixed) to rack on the aluminum member
If you cut the bolt hole brackets off the early rack and check the diameter of the rack you might be able to mount it. I think you will have to make some bushings.
Bob Dodd - 924turbo@cox.net
Zuffen
PostPosted: Sat Mar 20, 2004 1:02 pm    Post subject: Reply with quote
oh yeah and tie rod maybe completely different on the rack attachment point
