david_bryan
Posted: Fri Mar 05, 2004 4:19 am Post subject: Cold Start |
| Latley my 931 has been having some cold start problems. Every morning i have to turn my key over 5 minutes before i get the engine going. Once i get it started, it runs fine. Im tired of looking studip trying to start my car up for five minutes after everyday after school. Any suggestions? |
Joined: 29 Jul 2001 Posts: 9131 Location: Royal Oak, MI, USA
Posted: Fri Mar 05, 2004 5:25 am Post subject: |
Two areas to look at: is the cold start injector working, and is the fuel system retaining pressure after engine shutdown (and continuing to hold that pressure over time)? Info should be in the FAQ on checking the cold-start injector, and the fuel pressure test procedure is in the Haynes, at very least. _________________ Vaughan Scott
Minus000
Joined: 29 May 2003 Posts: 363 Location: Sidney, B.C.
Posted: Fri Mar 05, 2004 5:28 am Post subject: |
I would suggest it could be fuel pressure when cold. I would start by checking the operation and output volume of the fuel pump, ensure the pump relay is working properaly and if both turn up okay. Check your fuel pressure, if it is leaking start blocking off lines and isolate the the source of the leak.
Really though, more information is need. Have you checked that your plugs and ensured you had a good spark while cranking? If your spark plugs are wet it could be gas or coolant coating them and preventing them from firing. |
