OT: VW 16V leaking oil
CBass
PostPosted: Fri Feb 27, 2004 1:53 pm    Post subject: OT: VW 16V leaking oil Reply with quote
I just bought a '92 Passat with the 2.0 16 valve motor, with a 5 speed. I love the car, but it's got two oil leaks from the top end. The head gasket leaks from around the oil drains to the crank case, I'm told this is very common and is easily remedied by using a new gasket, they revised the old design and fixed it.
The other leak is what concerns me, the oil seal in the distributor shaft is leaking, and it's filling the distributor with oil, according the mechanics. I haven't looked yet myself, but I'm not too happy with it.
Does anyone have any experience with leaky 16V motors who could lend some insight here? I don't want to replace the whole distributor if I don't have to, it should be just the seal, right?
Diesel
PostPosted: Fri Feb 27, 2004 10:13 pm    Post subject: Reply with quote
If it's German, it leaks. Just check my sig. Anyway, have you checked your crankcase breather? When you start spouting spontaneous leaks sometimes it means the crankcase pressure is too high, maybe the PCV valve is bad. Can't hurt to take a look.
Dan Flanagan--2002 VW Jetta TDI, 83 Mercedes 300D,83 Mercedes Euro-240D
CBass
PostPosted: Sat Feb 28, 2004 7:18 am    Post subject: Reply with quote
True, I didn't think to check that, thanks Dan
