Headlight
bush0117
PostPosted: Sat Feb 14, 2004 10:10 am    Post subject: Headlight Reply with quote
Got problem with my headlights. They keep going up and down when you turn them on. Replaced the relay on the motor but didn't help. Has anyone experince this? Or know want might cause this.
Thanks,
Jason
Neil924
PostPosted: Sat Feb 14, 2004 10:14 am    Post subject: Reply with quote
Lizard will know.
PostPosted: Sat Feb 14, 2004 10:35 am    Post subject: Reply with quote
it is getting intermitant signal probably or a loose plug, take off the plug and make sure all the pins connectors are good, I have seen a pin fall just inside the motor housing causing this same thing
3 928s,
