lightweight flywheel, performance exhaust/header???
cleethorpes
PostPosted: Fri Jan 30, 2004 8:27 am    Post subject: lightweight flywheel, performance exhaust/header??? Reply with quote
Does anyone know of any uk suppliers for these?
Have only found one exhaust system supplier, haven't heard of them, and its £425(not even clear if that includes the header!)
PostPosted: Fri Jan 30, 2004 9:03 am    Post subject: Reply with quote
MSDS supplies headers for the 924, and they *may* carry lightweight flywheels, although it looks like someone here might be thinking of starting a run of lightweight flywheels here
3 928s,
simsport
PostPosted: Fri Jan 30, 2004 9:26 am    Post subject: Exhausts and flywheels Reply with quote
The exhaust header will do nothing much on its own, I have tried it!
You will also need to use a cam and do a bit of work on the head then the exhaust adds power.
The very light alloy flywheels are great but you can take a good amount of meat off a standard flywheel, so much so you can really feel the difference.
Any good engineering shop will be able to do that.
There is also an exhaust manufacturer in Macclesfiled that may be able to put together a complete system for you. I think they are called tube torque.
Cheers
Simon
Blown is always best!
AppleBit
PostPosted: Fri Jan 30, 2004 5:44 pm    Post subject: Reply with quote
Shipping from the states on a flywheel should be just above $50 for casual shipping.
You can shave a lot of weight- and I am very satisfied with that-- but WHOA the difference by going to an aluminum is awesome!
I finally noted a problem with aluminum flywheels this past week. It's well below zero (Currently -16 F and Feels like -33 F) so when you downshift and punch the Scatty (my Saturn) the clutch slips quiet well. Reason for this is aluminum dissipates heat so well that the flywheel never warms up. Nothing to worry about if you never punch your car down when it's crazy go nuts cold outside though
Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine
cleethorpes
PostPosted: Fri Jan 30, 2004 6:08 pm    Post subject: Reply with quote
If shipping is only $50 for the flywheel.
I presume a header and flywheel will be around $100, which could be worth spending as NO ONE seems to sell any decent 924 performance products in the uk, no one, why is that? There are loads about?
Plenty of mat sets, door handles, mundane parts, but ask for performance parts...slight pause...then a chuckle....then ...mmmmmm no!
AppleBit
PostPosted: Fri Jan 30, 2004 11:34 pm    Post subject: Reply with quote
I am __SURE__ I have seen websites in the UK that sell performance parts for the 924... I have seen them before, not being ignorant or anything but I don't really look for them in the UK since I live in Sunny Minnesota (-24 degrees currently).
PostPosted: Sat Jan 31, 2004 1:42 am    Post subject: Reply with quote
Applebit,
your aluminum flywheel does it a friction surface (steel plate) attached to it or is it just straight aluminum?
3 928s,
AppleBit
PostPosted: Sat Jan 31, 2004 2:06 am    Post subject: Reply with quote
steel plate. The only thing is that since the majority of the flywheel is aluminum this is the reason why it dissipates heat so rapidly...
PostPosted: Sat Jan 31, 2004 2:31 am    Post subject: Reply with quote
ok, keeps less heat at the back of the engine helping cyl #4
3 928s,
