BTRacing
Posted: Thu Jan 05, 2017 1:44 pm Post subject: |
Thank you !
Roof panel will be replaced with no sunroof fiberglass panel.
Tip: make sure that your tube notching is very tight.
Spend the time to fit them as close as possible. It takes a while but it is easier to fill the gap and will give you stronger joint.
Make sure that your heat is set right,practice on the scrap piece of tubing to set the welder right.
Take your time.... Cage is your safety. _________________ www.btrpalmbeach.com
1979 931 GTR Le Mans replica to be
2008 Audi S4 Avant daily driver
2008 Aston Martin Vantage
1974 Moto Guzzi Cafe Racer
1979 Glastron CVX 20 |
peterld
Joined: 10 Dec 2006 Posts: 983 Location: Noosa Heads QLD Australia
Posted: Thu Jan 05, 2017 11:14 pm Post subject: |
Such a nice job.......with beautiful welds. Bravo! _________________ 80/81 932/8 ROW |
Dutch924-racer
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Fri Jan 06, 2017 4:30 am Post subject: |
great project!
Do you have more info/ pictures on the sunroof delete conversion ? _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Forge recirculation valve + boost controller |
Mike9311
Posted: Fri Jan 06, 2017 5:17 am Post subject: |
| peterld wrote: | | Such a nice job.......with beautiful welds. Bravo! |
+1 one on that
tigging a cage, nice!! ...and your fitment of the tubes also very nice _________________ 1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
Posted: Fri Jan 06, 2017 4:06 pm Post subject: |
Think I spy a late rad support in there... _________________ Toofah King Bad
BTRacing
Posted: Fri Jan 06, 2017 11:40 pm Post subject: |
Yes it is late model radiator support. First idea was to run 944T intercooler with GTS intake, but I think I want to build a larger ,custom intercooler that would look closer to original. _________________ www.btrpalmbeach.com
BTRacing
Posted: Sat Jan 07, 2017 1:03 pm Post subject: |
Just got my fiberglass roof panel. Pretty good quality. I will post some fitment pictures next week. _________________ www.btrpalmbeach.com
Dutch924-racer
Posted: Sat Jan 07, 2017 4:44 pm Post subject: |
Do you have a picture of the front of the roof above the windscreen ?
Where did you cut is the roof in the front ?
thanks! _________________ 937 trackday car
Series 2 engine
Fast road camshaft
BTRacing
Posted: Sun Jan 08, 2017 7:59 am Post subject: |
Some of you asked about pictures of roof removed ,here they are
BTRacing
Posted: Sun Jan 08, 2017 8:01 am Post subject: |
Dutch924-racer
Posted: Sun Jan 08, 2017 5:34 pm Post subject: |
Great, many thans!
How much work was it, you did it all with point drill, and only cut the 'a' pillar? _________________ 937 trackday car
Series 2 engine
Fast road camshaft
Posted: Sun Jan 08, 2017 6:48 pm Post subject: |
| Dutch924-racer wrote: | Great, many thans!
How much work was it, you did it all with point drill, and only cut the 'a' pillar? |
No cut at the a pillar. Just a 'join'. Grind back to expose spot welds and joins. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
BTRacing
Posted: Tue Nov 24, 2020 9:04 am Post subject: |
BTRacing
Posted: Tue Nov 24, 2020 9:05 am Post subject: |
BTRacing
