kondzi
Posted: Wed Jul 12, 2023 6:34 pm Post subject: |
Would be nice to scan these in 3D and try to arrange one on the other in CAD software to see where the differences are. Unfortunately I don't have access to a 3D scanner and none anywhere nearby commercially available as I was checking. I don't want to send those though, being afraid I will lose my only mold I have  _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Wed Jul 12, 2023 6:42 pm Post subject: |
If you want, you can send them to me, i'll scan them for you and send them back. _________________ Supercharger and EFI kits
Mike9311
Posted: Thu Jul 13, 2023 7:46 am Post subject: |
Morghen, maybe you can lend your input to this thought. Maybe he is missing the fin in the final cnc version because of the conversion from scan to a surface in the CAD software? The scan has such finite detail which then gets smoothed out when converting. Then, in a much smaller way, you have both the CNC software as well as the cnc itself 'smoothing' the tool path while following the surface within a specified tolerance
This is the issue I have been having myself as I convert the port from scan data to a surface. _________________ 1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
Posted: Thu Jul 13, 2023 5:10 pm Post subject: |
Data conversion algorithms will always have an impact on actual values.
Generally i avoid using convertors, whatever i scan, i re-design myself by hand "under" the scanned surface. This gives me greater control over the resulting geometry but of course it takes a lot of time.
So if there is a mistake, i made it, not the software.  _________________ Supercharger and EFI kits
Mike9311
Posted: Fri Jul 14, 2023 11:19 pm Post subject: |
| morghen wrote: | Data conversion algorithms will always have an impact on actual values.
So if there is a mistake, i made it, not the software.  |
Nice, I know how that goes! _________________ 1980 931 since 1989
kondzi
Posted: Sun Jul 16, 2023 5:34 am Post subject: |
Thanks Ciprian, what I’m afraid is the courier losing the package
Currently I can live without the scan. I got the STP file though. But I only have a viewer. Can this step file be converted to something more useful? _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
Posted: Mon Jul 17, 2023 4:33 pm Post subject: |
Yes it can.  _________________ Supercharger and EFI kits
kondzi
Posted: Wed Jul 19, 2023 7:58 am Post subject: |
Guys I discovered something nice today
I was resurfacing the heads on my lathe, and after that, cleaning the heads to prepare them for assembly in some time. As I was paying attention to get all that hair size aluminium leftovers removed, I discovered the seat, that was a 3-angle cut by factory, is no longer 3-angle seat. Now it's radius cut!
That could explain those few CFMs over my hand ported job results on flow bench, right?  _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
kondzi
Posted: Sat Oct 19, 2024 9:30 pm Post subject: |
Darn, how much I missed, No time to go through all of that.
But Anyway, yesterday it was dyno tuning day for the car with the above mentioned heads.
I got 320HP and 380Nm. I’m very pleased with the results (70HP gain and 70Nm gain over stock engine).
Will try to attach the dyno chart later.
Have a nice WE guys  _________________ ---
Konrad
'89 951 US
'81 931 RoW (TBD)
