nickthompson
Joined: 26 Mar 2013 Posts: 873 Location: Central Georgia
Posted: Sat Jan 24, 2015 9:42 pm Post subject: |
This one from a 1999 Cavalier looks like it would work great. Plus I could pick one up at a junk yard for cheap for fitment purposes. |
Posted: Sun Jan 25, 2015 12:16 am Post subject: |
If you go to the junk yard might grab the master as well. . .another variable will be the volume of fluid needed for actuation. _________________ Toofah King Bad
nickthompson
Posted: Sun Jan 25, 2015 10:04 am Post subject: |
Test fit tomorrow!
nickthompson
Posted: Mon Jan 26, 2015 5:22 am Post subject: |
Well it's bolted to the torque tube. About to make some mount pedestal templates.
Posted: Mon Jan 26, 2015 5:48 am Post subject: |
That engine is small.
Looks good tho, i see its tilted properly, will you have enough room for the turbo? _________________ Supercharger and EFI kits
nickthompson
Posted: Mon Jan 26, 2015 5:57 am Post subject: |
I think it might fit. The hood clearance is going to be measured in the millimeters. |
leadfoot
Posted: Mon Jan 26, 2015 2:28 pm Post subject: |
pretty sure you can drop the cross member up to around 5mm before you run into the issue of having to elongate the steering shaft or using longer studs at the chassis attachment points, add in shims to accommodate the drop.
every little bit helps right...
Stu _________________ 1981 ROW 924 Turbo -
carbon fiber GT mish mash
nickthompson
Posted: Wed Feb 04, 2015 10:10 am Post subject: |
It sits on it's mounts.
Posted: Wed Feb 04, 2015 4:41 pm Post subject: |
That looks pretty good but I would reinforce the mounts somehow as there is a big mass sitting on them dynamically. So for example the crossmember is stressed torsionally because it has a long lever you just welded on.
I would at least lengthen the support downwards until the end of the crossmember...if not continue the supports on the front side.
The 40-50mm of weld you did might not hold that long. _________________ Supercharger and EFI kits
nickthompson
Posted: Wed Feb 04, 2015 6:36 pm Post subject: |
| You can't see it in the picture but they will be supported from the back side by a threaded rod attracted to the original mount point. |
leadfoot
Posted: Wed Feb 04, 2015 7:06 pm Post subject: |
hmmm, personally I would have made new mounts off the chassis rails... your location is quite far back to warrant this as opposed to bringing them forward to the crossmember, similar to what macbdog did with his chev conversion...
nickthompson
Posted: Mon Mar 09, 2015 7:37 am Post subject: |
I made an oil pan. Please excuse my poor welding. I know it has a hole in it. I bought a cheap used one incase I screwed this one up I wouldn't lose money on it. The hole had a rubber plug in it, I plan on welding closed then I'm going to pressure test it and paint it if it passes.
nickthompson
Posted: Fri Apr 10, 2015 10:30 am Post subject: |
1.8 pistons are light and small.
nickthompson
Posted: Sun Apr 19, 2015 5:18 am Post subject: |
I finished my oil pan and crossmember then painted them. I finished the downpipe. Also received almost all the parts I require for the bottom end build.
nickthompson
Posted: Sat Jun 06, 2015 11:04 pm Post subject: |
Freshly polished crankshaft ready for reassembly
Cleaned up my VW pistons and got them ready for install.
