StienbargerR
Joined: 28 Oct 2005 Posts: 1362 Location: Richmond, IN
Posted: Fri Feb 23, 2007 10:07 am Post subject: |
I'm 18.
My dad and I split the cost on the car pretty much. We bought my old one and he said if I could get it to run, he would help me out alot with the other costs. So here I am with this V6 conversion that pretty much dropped into my lap. I supose I've just gotten randomly lucky twice finding affordable cars (well at least the purchase price)
Ryan _________________ 1978 924 NA
-250lb lowering springs, Euro Pistons |
StienbargerR
Posted: Mon Feb 26, 2007 6:32 am Post subject: |
Yuck. Took it for a spin today, we broke down. The cracked block must be worse than we thought. Looks like I am either gonna buy a short block, or something. I'm nervous is going to get a little more expensive now. If anyone has a short block 4.3 with a balance shaft, shoot me a PM
turbobob9242
Joined: 08 Feb 2003 Posts: 138 Location: Hinckely Ohio
Posted: Mon Feb 26, 2007 10:21 am Post subject: |
I have a 89 or 90 checy V-6 short block in the garage. It will need to be cleaned up. _________________ Bob Ward
80 9214 turbo, w 5.3 LS V8 |
StienbargerR
Posted: Mon Feb 26, 2007 10:28 am Post subject: |
bob,
does it have the balance shaft? Mine is the vin W or w/e. Didnt some of the earlier 4300's come sans balance shafts?
StienbargerR
Posted: Mon Feb 26, 2007 10:29 am Post subject: |
oh, my other thought was just dump the vortec all together and find a chevy engine that will fit under the hood with no cowl. Any ideas? I think an ls-1 is a little above my price range.
turbobob9242
Posted: Wed Feb 28, 2007 10:59 am Post subject: |
I don't know for sure, I think no. _________________ Bob Ward
Posted: Wed Feb 28, 2007 2:19 pm Post subject: |
Here's a great site for finding used parts near you:
http://car-part.com/ _________________ White 87 924S "Ghost"
jamez
Joined: 03 Nov 2002 Posts: 401 Location: Chehalis, Wa
Posted: Thu Mar 01, 2007 3:47 pm Post subject: |
get an LT1, they can be had for around $1000. check out my car if you need ideas: http://www.content2drown.com/924LT1/
you will have a very fast car, just don't kill yourself |
StienbargerR
Posted: Sun Mar 04, 2007 7:20 am Post subject: |
Im thinking of selling this car, depending on if anyone is interested in it. I'm going to college soon, and it would have to be parked outside all the time. If your interested, go look in the for sale forum.
StienbargerR
Posted: Tue Mar 06, 2007 11:10 am Post subject: |
Well
Just got done doing a compression test. I was suprised, each cylinder is pretty much in the same range. I figured one would have no compression at all or something. I wonder what that damned noise is that it keeps making...
PORSCHEV
Posted: Tue Mar 06, 2007 11:30 am Post subject: |
A cracked block would either leak coolant fluid or oil....maybe both! If your getting bottom end noise it is more likely a bad connecting rod bearing. By the sounds of things with you going off to college, your better off either storing the car until you have time and money to complete it or sell it.
If you went the Lt1 route you going to run into an entirely new set of problems such as cooling it, buying a new rad, buying headers a wire harness...and thats just the short list.
It would be much easier to buy another replacement engine like the one you have( complete) and drop it in over a weekend and be done with it. _________________ 1976 924
1978-#53 "D" track racer. |
StienbargerR
Posted: Tue Mar 06, 2007 11:42 am Post subject: |
Ok. Thats Porschev. I figured that choosing a different engine would be alot harder. I will have a look at the oil and see if there is anything nasty inside. Would this cause it to overheat?
Thanks,
PORSCHEV
Posted: Tue Mar 06, 2007 11:47 am Post subject: |
Well....tell me what kind of noise is the engine making? Overheating can be cause by many things...like blown head gaskets, air locking etc. _________________ 1976 924
StienbargerR
Posted: Tue Mar 06, 2007 11:50 am Post subject: |
Well, it sort of makes this 'whumping' noise It definately comes in the same intervals, and it goes faster when the car revs. I thought it was coming from the driver's side bank, if that helps. I think I will try to record the noise this weekend.
PORSCHEV
Posted: Tue Mar 06, 2007 11:52 am Post subject: |
I realize that your 18..and when i was your age I didn't know alot about cars either and learned by getting my hands dirty like your doing. The only thing that the compression test will tell you is if your cylinders are leaking and that's not related to a bottom end knock or a over heating issue. It does tell you that your valves are all opening and closing fine and that you don't have ring leak down or any holes in your pistons/ cylinder walls.
Does the car smoke white somke when it runs? _________________ 1976 924
