Posted: Mon Nov 03, 2014 4:56 am Post subject: |
My problem with using the mat rather than cloth is that I normally use epoxy(West System) and the mat surface treatment is made for using polyester based resin. For me polyester has always been a rather poor adhesive. Granted I normally work with epoxy in a more structural systems than the dash requires, but it is just my normal working material so I just don't think about it. _________________ Mike
sciroccosteve
Joined: 16 Apr 2012 Posts: 215 Location: Rochester, NY
Posted: Sun Aug 09, 2015 12:10 pm Post subject: |
curious how this has held up, thinking of doing the same to mine _________________ 1979 924
2000 V6 Passat
"Let the fools have their tar tar sauce."
C. Montgomery Burns |
Posted: Fri Aug 21, 2015 12:45 am Post subject: |
Where I used the epoxy and fiberglass it has held up very well and the fiberglass is a fine enough weave that it doesn't show thru. I had one crack reopen in the face. If doing it again I'd cover the parts of the face that I could. Around the gages would get pretty dicey.
Since you're in NY what I would do is all the prep work with the filler which takes 90% of the time and then look up Brad Gillespie at Gillespie Paddles who is /or was in Rochester and see if he would do the glassing. He would have all the materials and epoxy and I could supply the glass if needed(its only about $5.00 worth). He does this stuff all the time. If you haven't used fiberglass and epoxy there is a short, but not penalty free learning curve. _________________ Mike
Lefty
Joined: 14 Oct 2013 Posts: 61 Location: Sydney, Australia
Posted: Wed Sep 16, 2015 6:11 am Post subject: |
The results look great and I was wondering How is the dash holding up after 3 years
Cheers
Lefty _________________ One less beige car |
Posted: Fri Sep 18, 2015 11:02 pm Post subject: |
Unfortunately some of the cracks which I did not fiberglass fave opened up again. The part that works best is where I basically reskinned it. Frankly, I think reskinning is the answer. I did all the more or less horizontal surfaces and ignored the front thinking it wuold get sloppy, I should have continued on with about 2" wide strips over all the vertical cracks. The bed spray on stuff I used covered the seams well enough so that they disappeared. Trying to glass around all the complex curves would get messy, and I have worked this stuff for many years.
I used type 2112 2oz fiberglass available from Sweet Composites(my supplier for the past 30 years), Fiberglast Developments(Expensive) of Fiberglass Supply and many others. I could send the necessary yard in a USPS mailer and It is only about $3 or $4 for the cloth. I used West Epoxy although any of the other thin boat building epoxies would work just as well. If they weren't so expensive to ship around I could do the fiberglassing. The filling takes more time than I care to spend.
Make no mistake, this is still a budget process and does not have nearly the same result as a proper and expensive recover.
If I left something out here sorry, Have a flat tire on the rented skidsteer and have to run off. _________________ Mike
