Illustrated Guide to 5-lug Conversions
Goto page Previous  1, 2, 3  Next
Martijnus
PostPosted: Mon Jan 26, 2009 7:48 am    Post subject: Reply with quote
Just started my conversion. Left rear wheel is installed
Left hub nut came loose after some blocking with a bar...but the right one didn't...had to cut it...
Can't use the 4 bolts for the brake carrier (or whatever it's called), they're shorter than on a disc unit.
Have some troubles with the ebrake cable... unbolted a bar which had 4 long bolts.... is that the torsion bar carrier? Can in some way my alignment change or something like that? it's not on the ground so nothing can really happen...but still.
"Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Killed her at the Nurburgring, Porscheless at the moment
PostPosted: Mon Jan 26, 2009 8:02 am    Post subject: Reply with quote
The aluminum bar of mystery is to help keep the drivetrain from moving (relative to the passenger compartment) in a collision.
Rich H
PostPosted: Mon Jan 26, 2009 8:46 am    Post subject: Reply with quote
Unfortunately the bits I was to get were rotten as a pear, on the hunt again...
What purpose to the backing disks have? The ones I have are in poor condition, are they really needed?
Martijnus
PostPosted: Tue Jan 27, 2009 2:24 am    Post subject: Reply with quote
thank you
had a hard time to find replacement axle nuts... bought some online for a VW beetle... should fit if I'm lucky.
Rich H
PostPosted: Tue Jan 27, 2009 2:41 am    Post subject: Reply with quote
gsfcarparts.com list them for about £3 IIRC
Also partsforporsche.com (.co.uk?) have them too in the UK.
Beetle ones should be OK though.
Martijnus
PostPosted: Tue Jan 27, 2009 3:46 am    Post subject: Reply with quote
I've been to a few suppliers, but they all couldn't help me or didn't want to put in any effort (except for one VW/audi dude).
Got a webshop from a friend... 16eur for 2 nuts (9eu for a pair)+a pair of splitters (dunno what they're called.. 2 eur) and shipping (4 eur).. so it's good enough.
Just found out that the DIY store doesn't have 36mm tools
Martijnus
PostPosted: Tue Jan 27, 2009 7:34 pm    Post subject: Reply with quote
nice...delivery just under 20hrs so that'll be seemless work.
Dunno though how to get those darn things at 300-400nM.....if my calculations are right I need a wrench of 50cm leverage and then put 80kgs on it... I'm 60kgs so I need more than 50cm boom
Martijnus
PostPosted: Sat Jan 31, 2009 2:47 am    Post subject: Reply with quote
Dan, I couldn't find it in the thread, but can you explain how to adjust the rear drum stuff for the emergency/parking brake?
There's a toothed wheel to adjust the brake shoes... I adjusted it my checking when both wheels had similar 'brake' performance with the ebrake engaged...but I'm not satisfied with the performance of the parking brake.
PostPosted: Fri Aug 21, 2009 3:34 pm    Post subject: Reply with quote
If you're sourcing the alu trailing arms try to get the M14 bolts that hold the rear shocks in place at the same time. Depending on your location they can be a right arse to source separately...
Still searching...
PostPosted: Fri Aug 21, 2009 5:22 pm    Post subject: Reply with quote
Gavin, I may have a couple of extras lying around that might be functional. But you can also use standard off-the-shelf hardware, M14x90x1.5. I had no problem finding those, and I believe the threaded boss on the alu arm is deep enough to accommodate the add'l 5mm (depending on the configuration of the end of your shock)...of course a few extra washers can come in handy too.
PostPosted: Fri Aug 21, 2009 5:45 pm    Post subject: Reply with quote
I've been to a few places already and each have said "good luck!" when I asked for M14 in any size...
I find it hard to believe I won't find them somewhere here, but thanks for the offer - I'll let you know!!
RC
PostPosted: Fri Aug 21, 2009 8:03 pm    Post subject: Reply with quote
Bomond Trading
Orchard Rd.
Brookvale
PostPosted: Fri Aug 21, 2009 8:41 pm    Post subject: Reply with quote
Bomond Trading
Orchard Rd.
Brookvale
Of course, silly me. How'd I miss such a high profile company... love their website...
Ta.
PostPosted: Tue Sep 01, 2009 9:31 pm    Post subject: Reply with quote
Marty, sorry, I missed this question earlier.
The procedure on Clark's Garage is good, try using it:
http://www.clarks-garage.com/shop-manual/brake-05.htm
PostPosted: Sat Mar 06, 2010 5:00 am    Post subject: Re: Aluminum-based 5-lug Conversion Reply with quote
If you source spindles from a 1985.5 or later 944, you MUST also source the strut housings, as the bolt pattern and flange width on the spindle are different than the early cars.
Just reread this. . ."late" 944 spindles will not have the correct geometry for a toofah with stock fenders.
Page 2 of 3
