931 stock boost levels /safe boost levels on stock internals
Goto page Previous  1, 2, 3 ... 8, 9, 10, 11  Next
Mike9311
PostPosted: Tue Jan 31, 2023 6:25 am    Post subject: Reply with quote
Small but nice side benefit of the turbine change is that you get a 7mm Left Handed Nut. At least you will know your nut and fancy compressor wheel won't come off
1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
1982 931 wana-be GTR race car
kondzi
PostPosted: Thu Feb 02, 2023 8:44 am    Post subject: Reply with quote
Mike9311 wrote:
Mike how much impact will that have? Roughly...
I lack time recently, a lot, and this means I need to cut the intake manifold, get laser cut flange and weld it together.
I though also about cutting out a V-shaped part of the runners of the 1.8T intake where the injection ports are to get rid of them and straighten the runners, but it's still time consuming and I still need the adapter CNC machined to attach to CH.
Konrad
'89 951 US
'81 931 RoW (TBD)
Mike9311
PostPosted: Fri Feb 03, 2023 1:07 am    Post subject: Reply with quote
Now you have me wanting to try. Maybe I could use Cedric's idea to print a manifold piece but make it straight like this
I'll add it to my to-do list
If you saw the CS head build thread update, the stock intake doesn't really change things that much. Lost a tiny bit at low lift and actually gained at high lift. Kind of nice actually
1980 931 since 1989
kondzi
PostPosted: Fri Feb 03, 2023 7:10 am    Post subject: Reply with quote
Yeah I saw it I remember that for N/A a lot of things matter. Like the lenght of the intake runners to the throttle body (resonance of the waves etc).
I’ve been playing around with VarioRam in a 964 (you can change the length of runners and also introduce / enable resonance chamber). It took some time to tune it properly on the dyno and we ended up close to the factory settings in the end. Mr Vizard says shape matters, not finish. If I think about the radiuses and diameters in the intake - there is not much where this could hurt the flow, it’s low velocity compared to the head port and no valves on the way. When looking at the CGT and GTR intakes these are rather short, so according to my knowledge more HP focused than torque focused. Personally I like torque over HP.
With this long intro, I think if the radius is big enough, be it, it will not make that much difference for the flow. But would love to see this on the chart measured
Konrad
'89 951 US
'81 931 RoW (TBD)
kondzi
PostPosted: Sun Feb 26, 2023 10:30 pm    Post subject: Reply with quote
Damn it's time consuming to install this with engine and exhaust in place. It took me at least one hour for one (top back) of the 4 bolts that secure the mount bracket with oil feed to the bloc, remaining ones was easier, still it took in total like half of a day.
Konrad
'89 951 US
'81 931 RoW (TBD)
PostPosted: Mon Feb 27, 2023 12:02 am    Post subject: Reply with quote
Yeah, for most type of more extensive 931 work its easier to take the engine out, and the end result is often better
kondzi
PostPosted: Mon Feb 27, 2023 3:12 am    Post subject: Reply with quote
I wish I was at this stage of knowledge about 924 turbos when I had my engine out
Konrad
'89 951 US
'81 931 RoW (TBD)
kondzi
PostPosted: Mon Feb 27, 2023 7:51 am    Post subject: Reply with quote
I managed to attach a banjo fitting at the wastegate and make a bit more room under the hood by installing the 944 reservoir.
I have an EBC solenoid (3 port MAC Valves one), I was guessing it's working on an on/off basis, but it seems I'm wrong? It has some frequency characteristic, so I expect this could work as a flexible boost adjuster? I.e. less boost at gear 1-2 and more at 3-4-5 by changing it's duty cycle?
[/img]
Konrad
'89 951 US
'81 931 RoW (TBD)
Mike9311
PostPosted: Thu Mar 02, 2023 8:08 am    Post subject: Reply with quote
Exactly Konrad so you can vary the duty cycle to control the air being bleed. The right ECU can control many things with this feature
Nice update
1980 931 since 1989
safe
PostPosted: Mon Mar 06, 2023 10:14 pm    Post subject: Reply with quote
[/img]
You can get about 2 times the boost of the wastegate spring with a 3-port and make it spool a bit faster than with just the spring.
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
kondzi
PostPosted: Tue Mar 07, 2023 5:40 am    Post subject: Reply with quote
I need to do some more shopping.
External BOV or recilculation valve?
Brand? Price tag? What you advice?
Then the IC. I found one from MAN L2000 that looks promising.
The inlet /outlet could be placed in the bottom of the radiator.
The shape of those is exactly to fit, it seems so.
Konrad
'89 951 US
'81 931 RoW (TBD)
safe
PostPosted: Tue Mar 07, 2023 6:12 am    Post subject: Reply with quote
Blow off valve is the least important, you can spend less on that.
If you want a recirculating one or dump to atmosphere is a personal preference, if you like the sound or not basically.
Porsche 931 -79
kondzi
PostPosted: Thu Mar 09, 2023 5:04 am    Post subject: Reply with quote
I ordered a used IC for fitment tests. Unfortunately I only managed to bring it to the garage as COVID hit me. So I need to get better and got some time at the same time, which I don't know yet will be.
Anyway in terms of width and height it seems I should be able to install it instead of the radiator. Unfortunately the stock air filter box will not fot for sure. Not sure if the fan behind the IC/Radiator sandwich will fit, or I will need to find one that pushes the air from the front.
So far so good. The IC is really solid, could be used as piece of construction for the front end IMHO haha. It comes from MAN L2000.
Not sure yet though the inlet/outlet will be at top or bottom.We'll see after removing the radiator.
Konrad
'89 951 US
'81 931 RoW (TBD)
Mike9311
PostPosted: Sat Mar 11, 2023 12:26 am    Post subject: Reply with quote
Dang! That is big. Reminds me of a Buick GN IC in a way. First pic you had did not give me an idea on size
1980 931 since 1989
kondzi
PostPosted: Sat Mar 11, 2023 9:20 am    Post subject: Reply with quote
Yeah, it’s rather big. I removed the radiator and it seems I’m missing 1 inch of clearance to fit this.
Now sorry for my english, let’s do descriptive. There are 2 panels/semi frames that go from the firewall to the front that the inner fenders are attached to and that create the stiffenes/frame of the front body. Those two narrow a bit in the radiator area.
I’m missing there less than an inch (2cm) and just thinking about making a small curved cuts to the sides of the IC to fit.
It’s a rock solid IC and for $50 I paid for it worth experimenting
Konrad
'89 951 US
'81 931 RoW (TBD)
Page 9 of 11
