Posted: Sat Jan 11, 2020 5:44 am Post subject: |
Yeah its a good idea. Im thinking of changing to a better oil separator than the stock one to keep the oil amounts out of the intercooler, or a second one as you thinking about. Oil mist in the air lowers octane aswell  _________________ 1980 924 Turbo
MOTANUL
Posted: Sun Jan 12, 2020 1:10 am Post subject: |
From what I checked in my car the original one does not really do a good job.
It almost does not retain oil at all. Just split it
If I think better I put a performance instead of the original. (it is redundant to keep both)
No oil in intercooler and air filter  _________________ 1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
sold Porsche 924 NA 1979 |
Posted: Sun Jan 12, 2020 1:25 am Post subject: |
Yeah, its mostly a empty can, and only take biggest particles /sone fluid oil. Many bling aftermarket products are not better though.
I might try a man hummel provent 200 that i might get my hands on, which should be waaay better than the std one. Its a bit clumsy though, a 150 would be better.
I work at a world leading company on this subject with active separators (oil driven mostly) for heavy duty vehicles as a responsible for separation performance development. So i have some knowledge on the subject  _________________ 1980 924 Turbo
Posted: Sun Jan 12, 2020 7:07 am Post subject: |
My aftermarket can which vents to atmosphere has mostly worked well. It used to have a cheap K&N style paper/gauze filter on top and it spat oil and mist over the left side engine bay. The current ITG foam filter has never done this, no oil splatter. Occasionally a light oil mist on top of the can needs wiping down after some big boosting/spanking. But is all good now. Limited clean ups. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
MOTANUL
Posted: Sun Jan 12, 2020 8:01 pm Post subject: |
I have never used aftermarket Oil Catch Can.
The expensive ones contain a filter in them (bronze filter).
https://www.youtube.com/watch?v=T-B4VRxAtbw
The 22 mm Inlets Size is not easy to find. I didn't measure the output exactly, but it looks pretty big too.
Which model best fits Porsche 931? _________________ 1980 Porsche 924 Turbo (931) diamond silver metallic/helios blue metallic
MOTANUL
MOTANUL
Posted: Fri May 29, 2020 1:49 am Post subject: |
The steering column rattles pretty badly. I replaced the wheel bearing. Almost no improvement
The bushing on the steering column is no longer available. Maybe I can put a teflon or polyurethane bushing.
MOTANUL
Posted: Sun Dec 27, 2020 12:42 am Post subject: |
I want to change the air vent system S1 with S2 (and by-pass air filter box)
I repaired the rod that had a broken screw in it since I had the car.
gaber
Posted: Mon Sep 12, 2022 7:45 pm Post subject: |
Do you have more photos of this roll cage?
What do you think about this one after some time?
Best regards,
Marcin
MOTANUL
Posted: Tue Oct 25, 2022 3:13 am Post subject: |
Ref. to: spare part Bearing bracket 477711237A (6 in the picture below).
Over time I accumulated 3 Shift mec. (Manual transmission).
I am curious if both parts in the picture are original. One appears on the Internet very often (I mean the one already mounted on the car) - the second one seems much rarer. (with white and no rust).
Posted: Thu Oct 27, 2022 11:22 pm Post subject: |
Mine looks like the one in your car if i remember correctly _________________ 1980 924 Turbo
MOTANUL
Posted: Sun Oct 30, 2022 5:43 pm Post subject: |
From what I understand, the white one is from 1979 924 NA (it is the model that has an additional spring).
From 1980, only the rubber model was installed (the rubber being very flexible, the spring was no longer needed). This model transmits fewer vibrations.
I found this topic discussed here in 2014: https://www.924board.org/viewtopic.php?p=358409&sid=b672000a3b1b2f8b9b6b247cbf8fe4ab
MOTANUL
Posted: Fri Nov 25, 2022 6:20 pm Post subject: |
I ordered an AFR. Where is the best position to mount it? Before or after wastegate pipe?
Posted: Sat Nov 26, 2022 6:10 am Post subject: |
Somewhere safe between the turbine flange and waste gate _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
MOTANUL
Posted: Sat Dec 03, 2022 7:39 am Post subject: |
I checked where the O2 sensor is placed on the American 924 turbo. It is placed very close to the turbo flange. (in fact, in the respective area it does not interfere at all).
Further back is the oil filter, further back is the wastegate system, after which comes the intermediate drum.
The instructions mention a distance of at least 45 cm for aspirated cars and 90 cm for turbo cars.
I measured and 90 cm means somewhere in front of the intermediate drum.
I mean, whatever I do - it doesn't turn out well.
