Posted: Sat Apr 20, 2013 5:31 am Post subject: |
Jason, is this for that block you got from me? If so, and you do this, I'd be interested in the rods and pistons from this block. dave. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
flosho
Posted: Sat Apr 20, 2013 6:30 am Post subject: |
| Grenadiers wrote: | | Jason, is this for that block you got from me? If so, and you do this, I'd be interested in the rods and pistons from this block. dave. |
Indeed, the rods are probably good, but the top of those pistons look pretty beat up... I don't know what is acceptable and what isn't.
Otherwise I always have the engine that is in the car that could be broken down after the build. _________________ [This Space For Rent] |
flosho
Posted: Wed Apr 24, 2013 5:03 am Post subject: |
I just checked out my local machine shop and they are very reasonable to offset grind the crank.
I believe I've got the correct (longer) rods picked out and am trying to find a piston that gives me somewhere in the 8.6:1 to 9.1:1 CR. _________________ [This Space For Rent] |
Posted: Tue Jul 09, 2013 11:10 pm Post subject: |
Dan, whose ignition controller are you going to use for the EDIS ignition? _________________ Mike
Posted: Tue Jul 09, 2013 11:42 pm Post subject: |
Since this motor will never be EFI'd (due to the carbs), I am planning to use MegaJolt to debug the sensor mount, sensor position, EDIS tuning, and spark map tuning. _________________ erstwhile owner of just about every 924 variant ever made |
flosho
Posted: Sat Apr 12, 2014 12:43 am Post subject: |
bump. which off the shelf parts get me 88 mm pistons, 150mm rods, 931 _________________ [This Space For Rent] |
GeorgeV
Joined: 14 Mar 2010 Posts: 306 Location: Brisbane, Australia
flosho
Posted: Tue Apr 29, 2014 5:43 am Post subject: |
| GeorgeV wrote: | | Are you doing another rebuild flosho? I thought you had retired from 931ing? |
My love of the 931 is on life support and just barely hanging on. _________________ [This Space For Rent] |
Posted: Tue May 31, 2016 11:12 am Post subject: |
In situ.
procyon
Joined: 09 Sep 2015 Posts: 70 Location: Peers Alberta Canada
Posted: Wed Jun 01, 2016 1:39 am Post subject: |
Looks really good. I don't see a crank position sensor. Is it not fitted yet? _________________ 1981 924 N/A (Now the parts car)
1980 924 N/A ( 5 bolt discs and better paint) MS II V3.57
2003 Subaru Baja
2021 Maxda CX-30 |
Posted: Wed Jun 01, 2016 3:49 am Post subject: |
| procyon wrote: | | Looks really good. I don't see a crank position sensor. Is it not fitted yet? |
No, haven't had opportunity to mock up the bracket yet. I have the sensor, I have the trigger wheel and spacers fitted, just haven't done the bracket and pickup yet. So as not to introduce too many variables at once, I'm going to get the carb setup running reliably using the stock (conservative) ignition setup, and then swap in the programmable stuff later. _________________ erstwhile owner of just about every 924 variant ever made |
a239947
Posted: Thu Jun 02, 2016 1:35 pm Post subject: |
I'd love to know the part numbers of the pistons and rods used in this build. It would make it so much easier to find a local who might stock the parts. If not could you let us know the make and model of the cars these were for.
Figuring this stuff out is not that easy over this side of the world!
i hate to think what it was like in the non internet days! |
Noahs944
Joined: 08 Dec 2015 Posts: 782 Location: Calgary, Alberta, Canada
Posted: Fri Jun 03, 2016 1:05 am Post subject: |
My god, Dan... this engine looks so tight from any angle. Well done!  |
XLR8
Joined: 30 Mar 2016 Posts: 150 Location: Byron Bay, Australia
Posted: Sun Sep 13, 2020 12:00 pm Post subject: |
Hey Dan, did this work of art get rolling? _________________ '81 Porsche 924 NA
'89 Eunos Roadster NA6
'06 Landcruiser HDJ100 |
Posted: Mon Sep 14, 2020 10:45 pm Post subject: |
| XLR8 wrote: | | Hey Dan, did this work of art get rolling? |
No. Wanna buy it? _________________ erstwhile owner of just about every 924 variant ever made |
