Mike9311
Posted: Sun Mar 22, 2020 12:58 am Post subject: Turbo Drain Design Input (gauge) |
Hi All
Just wanted to get input on a 'not so important' side project besides tooling up for Morghen's 2470 wheel which I hope to do very soon before this project. Especially now that the hard deadline for the '82 has been delayed for obvious reasons. No joy rides here due to lock-down (back and forth to work however is still on table so far).
Been thinking of adding a temp gauge port to the turbo drain. Obviously the thread could be metric or inch.
Thoughts?
The last pic has me doing virtual test machining and you can see the boss for the sensor there. I likely would need to finish old school by hand since machining is somewhat difficult for the internals.
 _________________ 1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
Posted: Sun Mar 22, 2020 1:55 am Post subject: |
Interesting idea.
I'd want to make sure the boss is long enough that the probe doesn't stick too far into the flow and restrict it. I've seen some gauge adapters that aren't long enough and I've had to create extra spacers, particularly with the VDO temp senders, to get the probe out of the flow. Some would even go in so far as to touch the other wall of the tube, almost completely blocking the flow!
May also be worth verifying that the body (OD) of the sender will clear the turbo itself, housings, fasteners etc on installation. As that sits, it looks pretty close. _________________ Vaughan Scott
Mike9311
Posted: Sun Mar 22, 2020 3:00 am Post subject: |
| 924RACR wrote: | Interesting idea.
May also be worth verifying that the body (OD) of the sender will clear the turbo itself, housings, fasteners etc on installation. As that sits, it looks pretty close. |
Agreed on the sticking out of the sensor especially the one I have now. Its something like 1.7" after the thread. (IGNORE The note that says wastegate. Mental typo there.)
From what we see so far is the car body could be the issue. I would like if it would be in a pocket to the side enveloped in oil but not in the general flow area. However this could be great for the sender I show but maybe not for others.
Mike9311
Posted: Fri Mar 18, 2022 11:28 pm Post subject: |
Decided to divert slightly off the cylinder head for a couple of days to get back to this project. Easier to install on two cars when one is up on the lift and the other with engine out. Plus my skills were warmed up after just completing another job. Just makes it easier. Sender hole thread can be 1/8npt or metric.
Mike9311
Posted: Mon Mar 21, 2022 4:12 am Post subject: |
Update
Thread in for drain and gauge sensor on the opposite side inline with drain. This one is 1/8 NPT but its easy to make any thread for a sensor
Drain fitting threads are milled which lets me control fit. Almost done. Side 2 next
Mike9311
Posted: Thu Mar 24, 2022 10:52 pm Post subject: |
The rest of the inside to do and I'm done. Already farther than this pic
Mike9311
Posted: Fri Mar 25, 2022 10:48 pm Post subject: |
Just needs some hand finishing and mount holes opened up to size. Moving on to the next project
Posted: Sat Mar 26, 2022 6:39 am Post subject: |
Would buy..
Some day I’ll quit or get fired and have time for my cars again 🥺 _________________ 80 Turbo - Slightly Modified |
jacobroufa
Posted: Sat Mar 26, 2022 8:30 am Post subject: |
+1 Would buy _________________ 1980 Porsche 931
1981 Porsche 924 Weissach |
Mike9311
Posted: Wed Mar 30, 2022 6:56 am Post subject: |
Thanks guys
I feel you Eddie... I am working even when I'm not working. Got a 2nd on in the machine for the CS. Turns out these drop mass from 413 to -160g Side benefit to just wanting to know oil temp at turbo. Need to work on proper hardware too. Sensor is farther from exhaust than pic makes it seem
Mike9311
Posted: Mon Apr 04, 2022 1:40 am Post subject: |
Added simultaneous 5 axis porting now to improve the inner parts. I left material in the first one to port out by hand with a carbide burr. Not really fun and somewhat dangerous to the flange section if burr is too short and bounces why grinding.
CNC porting opened the second one up nicely. Still will clean it up manually but at a happier place with the finished product. _________________ 1980 931 since 1989
Posted: Mon Apr 04, 2022 1:53 am Post subject: |
Haven't gotten around to replying, but have been watching: beautiful work. _________________ Vaughan Scott
Mike9311
Posted: Fri Apr 08, 2022 11:38 pm Post subject: |
Thanks Vaughn!
I have a 2nd one done now for the Club Sport. It got the extra full 5 axis porting treatment with the lollipop. With it being fixtured horizontally, it was at a machine axis limit which then causes faults. This added so much time for me to work through the programming. Good exercise for me though since I want to do a head once flow-bench is running etc.
It lost some grams yet again in the process. True mass loss is 380g down to 129g.
In all this I am realizing how massive the process really is for auto manufacturers. Safety features, and what not, being added to a new car design and then trying to find where they can lighten to offset.
Posted: Sat Apr 09, 2022 6:08 am Post subject: |
What a project, in the engine dev world we just drilled/taped or welded in a bung for pt100 or thermocouples where needed, this is much cooler though A bit tricky to use the oil drain temp data for something useful, would be interesting to hear your plans  _________________ 1980 924 Turbo
Mike9311
Posted: Sat Apr 09, 2022 7:24 am Post subject: |
Thanks Cedric
I was thinking it probably is near useless for standard oil temp but I am just curious. Realistically i'd better have another gauge which the CS already has right off the oil drain
This started simply because I was scanning so I scanned the drain for fun. Then it just kept going
Machining it was straight forward and everything I do helps me develop skills. Maybe I was avoiding the cylinder head project? No more excuses _________________ 1980 931 since 1989
