Han Solo
Posted: Sun Jul 12, 2015 9:56 pm Post subject: My third 924 is a 931 restore thread |
Here we go again... This one was found local. It had popped up on Craigslist several times and then went away. I've looked at it and it's salvageable but that needs to happen soon. Non-runner. Door seals leaking. Moldy interior. But a complete car with shop manuals. Probably a two owner car. I'm going to start restoration thread on this forum as it seems to be the most active and informed for 931. It's a '82 with option codes 423, 425, 461, 650. Paint is LM9Y black. Give me a few days to figure out attaching photos here.
 _________________ -----HAIRY ANT NEST RACING-----
Collecting, racing and restoring Porsches for fun and negative cash flow.
-----Epic 914 race car build----- http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/767721-yet-another-rescue-porsche.html |
Posted: Mon Jul 13, 2015 12:45 am Post subject: |
Sweet. _________________ Toofah King Bad
Posted: Mon Jul 13, 2015 2:02 am Post subject: |
nice find.
I think LM9Y is silver not black but i could be wrong.
good luck and dont forget to post pics and progress reports here.
this forum has a lot of members, most dont post so ofthen but many read the news here  _________________ Supercharger and EFI kits
Han Solo
nickthompson
Joined: 26 Mar 2013 Posts: 873 Location: Central Georgia
Posted: Thu Jul 16, 2015 7:12 am Post subject: |
| Are you going to run those spiderwebs? If you change wheels I might be interested in thise. |
Han Solo
Posted: Thu Jul 16, 2015 12:57 pm Post subject: The saga begins |
Well I bought the 931 today. Before I dropped the cash, I pushed it a bit in 5th gear and the belts turned so I know the crank is free. It's got one area on the drivers rear fender that's been fixed and some of the paint is coming off, a small bit of rust and some bubbles. Other than that the body looks good. The interior is a bit of a mess. The passenger floor board was wet and I figured out that was coming from the battery tray. You could see wet leaf fragments where it was dripping and that carpet was getting green slime. There's some mildew on the seats. The PO had an aftermarket air dam put on the front fascia so that's probably coming off. Some crude wiring for radio shack speakers in the rear and an alarm horn in the battery tray (those all go straight in the trash). I also noted after market boost and temp gauges in a pod mounted to the center speaker grill. After unloading the car garage, first priority was to get the carpet dried out, vacuum, clean up the mildew and just get it where your not afraid to sit in it. I pulled the battery and found the rust hole (typical body filler fix gone bad). Next will be to follow the first start procedure I read on this forum after replacing the timing belt. This is going to take some time.
[/img] _________________ -----HAIRY ANT NEST RACING-----
Han Solo
Posted: Thu Jul 16, 2015 3:26 pm Post subject: |
Does not look too bad. A bit of work and this should be a nice car. _________________ Supercharger and EFI kits
Han Solo
Han Solo
Posted: Sat Jul 18, 2015 12:45 am Post subject: Seat extraction |
Got the seats out yesterday evening. The drivers was most troublesome with the rails being bound up by rust and crud. Liberal PB Baster fixed that. Then I peeled up the floor pan carpeting. The under layment was wet. Especially the passenger side. So I peeled all that out and tossed it. The pans don't appear corroded however. I left the carpet bunched up and box fan blowing all night. Everything nice and dry this morning. I also jumped in the engine compartment, pulled the air filter and housing. I was thinking that would be enough to get the timing belt cover off. I was wrong. Pulled the coolant hose to thermostat, took the alternator belt off and loosened up the snorkel where it joins the ???. Anyway, I wrestled out the cover and the belt looks okay and I found the camshaft gear timing mark. What's the mark look like on the crankshaft pulley? I want to confirm that it's timed correctly before ordering parts. My preliminary list includes...
timing belt
belt tensioner
alternator belt
fuel filter
water pump
oil filter
air filter
ignition wires
thermostat
radiator hose kit
distributor cap, rotor and plugs (which I already have, common to 914)
With those parts, some luck with the fuel pump and relay, I should be able to get this joker started. I'm also going to soak the cylinders with WD 40 before I start cranking.
One concern I'm having though, there's been zero coolant in this engine so far. I'm hoping that the water pump or a hose failed and it got shut down before damage occurred. I guess worst case would be cracked head or block. That would suck.
Posted: Sat Jul 18, 2015 1:28 am Post subject: |
Lovely color. Was this the car that was on CL in Murfreesboro TN? This looks like an excellent restoration candidate. _________________ erstwhile owner of just about every 924 variant ever made |
Han Solo
Posted: Sat Jul 18, 2015 1:42 am Post subject: |
I'm conflicted on the color. The options say black but is it? Yes, this is the CL car in Murfreesboro. I've been watching pop up and go away for about a year. After looking at it, I figured if someone didn't get it inside soon, it was going to really degrade. That rust hole in the cowl was letting a lot of water in.
OBTW - I replied to your PM.
| ideola wrote: | | Lovely color. Was this the car that was on CL in Murfreesboro TN? This looks like an excellent restoration candidate. |
Han Solo
Posted: Sat Jul 18, 2015 2:20 am Post subject: Paperwork inside |
Sorting through the paperwork that came with this one. 924 Turbo shop manual, 924 Climers manual, some insurance certificates and a dealer pre-delivery form. All indications are this was a one owner car! Delivered 12/29/81 at Vaughn Motor Co. in Murfressboro TN. Nice Christmas present. Last service stamp is 6/14/83 at 15,005 miles. Unfortunately no invoice present but getting just these documents is huge.
Han Solo
Posted: Mon Jul 20, 2015 7:53 am Post subject: Good news |
It's been a very productive weekend. I'm happy to report that I was able to get the engine on this 931 started. I spun the crank a couple of times by hand with the plugs out. Those came out looking okay. A bit toasty but no rust. The crank spun freely with no odd noises or resistance. I had a pretty new plug set from a 914 and put those in. I had been charging the battery that came with the car for a couple days and tried to turn it over with that - but no dice. I was able to check the headlights, tail lights and blower motors though. All good. I grabbed a new battery I've be using on a winch and got that hooked up. Turn the key and it's cranking good. Oil pressure light goes out. Put the plug wires on and give it a good shot of starting fluid. It catches, idles for a bit and then sputters out. I did that a couple more times and the idle gets a little better each time. Then I get a can of spray Sea Foam and start give good bursts of that into the AFM. It just gets better and better. I sprayed some into the vacuum line off the brake booster also. And I found why there was no engine coolant - the water pump is weeping bad so it's toast. But after coming up a bit in temp the radiator fans kick in big time and water in circulating. I'm very pleased with the fact there appears to be nothing major wrong with this engine at this time.
kcoyle
Joined: 15 Jan 2011 Posts: 712 Location: Long Island, NY
Posted: Tue Jul 21, 2015 10:51 am Post subject: |
I'm digging that kooky front spolier/valence thing going on there. _________________ 1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. |
