924NA to Turbo
xpernet
PostPosted: Sat Sep 25, 2004 7:38 am    Post subject: 924NA to Turbo Reply with quote
Hey Guys!
I was thinking about converting the 924NA to a 924 turbo, where i need to get parts from a 924T parts car, and fit it on the 924NA. I know its easier to buy a 924Turbo, but i havent seen any for sale. Do you think that the 924 turbo system, is better than the aftermarket ones? And how difficult is it to maintain? I dont know anything about turbo systems.
Also i have this weird problem, with the 924. When dad kicks into high speeds on a high-way, he feels heating blowing into his face!?!! Do you think that the fire wall may leak heat if cracked ???? Only the driver can feel it.
Thanx in Advance!!!
xpernet
1977 Porsche 924
Sunroof Delete
Megasquirt II EFI & EDIS
Carrera GTS / 944 Body
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
timstar92404
PostPosted: Sat Sep 25, 2004 11:47 am    Post subject: Reply with quote
i've heard its not worth it to turbo or supercharge a 924. I would think it is easier to supercharge the 924 na but don't think you can find a supercharger kit for th e924 if there was one i would buy it.
78 924 sold.
85.5 944
Sleykin
PostPosted: Sat Sep 25, 2004 12:05 pm    Post subject: Reply with quote
Be cheaper, faster and meaner to drop a Ford V8 in it (relly a cheby would be cheaper but I am a Ford person)
Glenn Neff
Medford, OR
87' 924S
timstar92404
PostPosted: Sat Sep 25, 2004 3:37 pm    Post subject: Reply with quote
i think putting a chevy or ford engine in a 924 is pretty stupid plus alot of hard work and money.
wuoldn't that just ruin any handling or balance that the car had? I really wouldn't want a gm engine in any porsche inlcluding the 924.
I think it would be cool if you could fit a vw vr6 engine in 924 those engines are pretty sweet.
78 924 sold.
85.5 944
Sleykin
PostPosted: Sat Sep 25, 2004 4:04 pm    Post subject: Reply with quote
I was being sarcastic. Sorry if you missed it ... must be the Tullamore Dew ... you'r cut off now.
Glenn Neff
Medford, OR
87' 924S
PostPosted: Sat Sep 25, 2004 10:41 pm    Post subject: Reply with quote
Oy, as much "fun" as I've had trying to get mine running properly with everything there, I don't think it'd be a good idea trying to add all the turbo junk to an NA and make it run! I'd recommend waiting till you find one...
flosho
PostPosted: Sun Sep 26, 2004 10:46 am    Post subject: Reply with quote
I got a 931 for sale, check out the for sale ads.
[This Space For Rent]
My924gtc
PostPosted: Sun Sep 26, 2004 10:57 am    Post subject: Reply with quote
Flo...I think the shipping costs to Lebanon might kill that sale.
xpernet
PostPosted: Sun Sep 26, 2004 4:24 pm    Post subject: Reply with quote
Thanx for your replies guys. So i think that i should buy a 924Turbo rather than installing a turbo system on an N/A.
But i didnt get a reply about the heat thats pouring in the car from the engine. I cant understand why such a thing is happening. Any sugestions ????
1977 Porsche 924
Sunroof Delete
WA924-77.5
PostPosted: Mon Sep 27, 2004 3:26 pm    Post subject: Reply with quote
About the heat :
1- I would make sure the coolant circulation valve into the heater is closed (engine coolant is not circulating into the heater)
2- could it be that your shifter boot is cracked and the heat is coming up from there (I had that happen)
xpernet
PostPosted: Mon Sep 27, 2004 4:27 pm    Post subject: Reply with quote
Thax WA924 for your reply.
Well, About the Coolant circulating to the heater, my heater core just blew up and all of the hot boiling water poured on to the passengers side where i was sitting. So our mechaninc cancled the line till we find a better replacement. And from what i have seen, he got rid of the pigtail pipe. So, could heat be leaking from the pig-tail pipe connection in the fire wall ?? And the heat pours like hell when the radiator fans kicks into high speed.
I checked the shifter boot and its perfect. The heat comes from under the dashboard according to what my dad said. I dont drive the car because i am still 15. I
Before i forget, i sealed a broken cap on the fire wall which passes some of the wires to the car's dashboard with silicon. It reduced the effect abit.
Should i be looking for a crack in the fire wall?
xpernet
1977 Porsche 924
Sunroof Delete
