searching for answers... :)
stamp
PostPosted: Sat Sep 11, 2004 6:56 am    Post subject: searching for answers... :) Reply with quote
Got my engine to finally turn over. have a couple of hopefully quick ones here...
1 ) what direction does the engine normaly rotate ie cw or ccw??
2 ) have recently gotten smoke or steam coming out of cis intake??? any ideas here???
3 ) should gas pump run all of the time or should it cut out once pressure is reached??
thanks in advance
stamp
dpw928
PostPosted: Sat Sep 11, 2004 10:47 am    Post subject: Reply with quote
The engine should turn CW when you are looking at it from the from. Smoke from the intake normally means the ignition timing is too advanced or the cam timing is off. The fuel pump should run all the time while the engine is running. When cranking the engine it should shut off after a few seconds if the engine doesn't start.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
numbbers
PostPosted: Sat Sep 11, 2004 11:10 am    Post subject: Reply with quote
The only way a 931 will crank backword is if you install an NA starter instead of 931/944 starter. Don't ask me how I know.
PostPosted: Sat Sep 11, 2004 11:16 am    Post subject: Reply with quote
and the exact opposit is the same with the 924 installing a 931/944 unit, again dont ask me how I know either.
3 928s,
stamp
PostPosted: Sat Sep 11, 2004 11:26 am    Post subject: Reply with quote
well, I think that I need to get a new starter... from the front its cranking ccw....
what if any dammage to this poor little car have I done??? ....
PostPosted: Sat Sep 11, 2004 11:57 am    Post subject: Reply with quote
Since I believe you have a 80 931, I would check the timing belt and make sure it's not loose. If you don't know when it was replaced last, replace it along with the tensioner.
The oil pump doesn't work when the motor is cranked backwards, but unless you have been cranking it a lot, I doubt you hurt anything.
PostPosted: Sat Sep 11, 2004 2:29 pm    Post subject: Reply with quote
if your timing belt skipped teeth then you may have bent your valves.
3 928s,
numbbers
PostPosted: Mon Sep 13, 2004 9:48 am    Post subject: Reply with quote
Cranking it backwards will not damage the 931, it just won't start.
PostPosted: Mon Sep 13, 2004 9:56 am    Post subject: Reply with quote
But cranking it backwards especially if its loose may cause the belt to slip.
stamp
PostPosted: Fri Sep 17, 2004 2:25 pm    Post subject: Reply with quote
well, I replaced the starter with the correct type. Fired it up.. and supprise... it acutally started... just about 50 deg advance... oops.
retimed it and it runs a little high on the rpm about 2000 or there abouts.
I've got the charger on the bat tonight. and will put a full tank of good gas in on friday morning.
other than that, she is a little hard to start right now, thinking because its the bad/old gas.
when you set the timing, where in the window is it set?? top, mid, or bottom?
thanks again.
PostPosted: Fri Sep 17, 2004 3:17 pm    Post subject: Reply with quote
the timing window is on the bellhousing near the top on the drivers side for LHD cars
3 928s,
PostPosted: Fri Sep 17, 2004 4:03 pm    Post subject: Reply with quote
You should find a recess and/or mark just below the middle of the window to line-up with.
stamp
PostPosted: Sat Sep 18, 2004 3:50 am    Post subject: Reply with quote
thanks, at least I'm using the right window...hehehe
I'm off to get brake fluid, and a long bleed hose, not too mention the good gas
