WTF
'79 924
PostPosted: Sat Aug 14, 2004 2:24 pm    Post subject: WTF Reply with quote
I need help big time!! My problem started when I took the car out for a short drive today, I always drive around the park once today to warm the car up before going anywhere. Well today I got about half way around and the fuel pump cut out and wouldnt restart. So I pulled over into the grass and popped the hood and one of the wires that goes to the + side of the battery had melted through. luckily my friend was with me so we pushed it back to my house and i fixed the wire. Now comes the big problem. The fuel pump will engage again but as soon as you turn the key to start you hear a click from some where in the front of the car and the fuel pump dies and wont come back on again for like 10 min. Do you think that any of this could be because I have the fuel pump hard wired to a switch? Thanx for any help you can give me. Have a great day!
Speed kills: drive a Honda and live forever
What does a stupid redneck say right before he dies? Hey y'all watch this!
'79 924, gaurds red
PostPosted: Sat Aug 14, 2004 4:32 pm    Post subject: Reply with quote
I would recommend that you find and remove the fuel pump relay once located and get a voltmeter and see how many amps the fuel pump is pulling, also then jumper terminals #30 and #87 and listen to the fuel pump if it stays running and you are pulling roughy 10 amps of power then you just have a dead fuel pump relay, and the wire could have been possibly bad or becoming bad previously.
3 928s,
'79 924
PostPosted: Sat Aug 14, 2004 4:57 pm    Post subject: Reply with quote
I dont have a relay, it was bad, had to tap on it with a screw driver to get it to work, so it ran wires from #30 and # 87 to a switch and use it. I went the cheapo route cause I was broke then as I am now.
'79 924, gaurds red
PostPosted: Sat Aug 14, 2004 5:03 pm    Post subject: Reply with quote
so this is happening with the switch even, then I would be looking at a defective fuel pump, or possibly wiring, that is why I said to do an amp load test
3 928s,
'79 924
PostPosted: Sat Aug 14, 2004 5:26 pm    Post subject: Reply with quote
thnx for the thoughts. by the way does anyone know of some one that is looking for a 924 that needs some tlc. im thinking of getting rid of this one and buying my friends '84 944 for $1000. all it needs is a drivers side fender and headlight cover.
'79 924, gaurds red
PostPosted: Sat Aug 14, 2004 5:33 pm    Post subject: Reply with quote
dont give up so easily man, that really discourages me to see that happen all around me.
andin regards to your signature I must disagree with you statement
the reason for my disagreement is you need to know what honda stands for "Hit Once Never Drive Again!"
3 928s,
'79 924
PostPosted: Sat Aug 14, 2004 6:03 pm    Post subject: Reply with quote
.a
'79 924, gaurds red
'79 924
PostPosted: Sat Aug 14, 2004 6:10 pm    Post subject: Reply with quote
oh so true. however, i know im probably going to get shit for this but i kind of like the crx's they make preatty cool little race cars. and can look cool without being riced out.
sorry about that last one kinda screwed up
Lizard; my reason for wanting to get rid of this car is that from day one i have had nothing but trouble with it. when i first bought it from my friends dad i wasnt able to drive a manual so he had to drive it home for me and on the way the exhaust blew out. after that i had to figure out why the fans wouldnt come on i searched and searched and couldnt find any reason why they wouldnt come on other than maybe bad wiring and finally just said F it and wired them to a switch with all new wiring. then there is the shifter, after sitting for a month or so the car would only go into reverse, 2nd, and 4th gears and i still havent been able to fix it. from the begining before the guy i bought it from bought it it had had problems with basically eating fuel pump relays for breakfast ( and lunch and dinner for that matter) and after sitting for about 3 months being started maybe once a month it wouldnt start at all one day. i figured it was the pump relay, and guess what it was. i didnt have the money to buy a new relay at the time and wired the pump to a switch and now this bull shit happens. i am begining to think that this car is cursed or something! i am planning on buying another 24 in the near future but right now this one is my only car and i need to find another and my friends 44 has been taken preaty good care of and looks to be a preaty good deal for only $1000. thnx again for the advice. ill try it but if it doesnt work i dont know what is going to happen cause i have tried to sell it before and have ended up taking the sign down because couldnt bring myself to sell it cause i love the damned thing so much caus it is such a fun little car to drive. ive been going on long enough so ill end this one. thnx again. have a good day!
'79 924, gaurds red
PostPosted: Sat Aug 14, 2004 7:00 pm    Post subject: Reply with quote
If you can't afford to repair and maintain a 924, there is no way that you are going to be able to afford a 944.
The "front of engine service" alone (required every 3 years or 30K miles to keep the engine from self-destructing) is going to cost you at least $500-$800 (if you only drive 10K miles a year, and put the money away every month until you need it) a year. If you can't afford $40 relays when they're broke, and you can't afford to pay someone to fix the problem, you can't afford a 944.
As you can tell, there are no Mickey Mouse repairs that will work for long on a Porsche. You gotta fix it right when it's broke, you you are just digging a big hole for yourself.
Any 944 you buy for $1000 is going to need expensive repairs. Try asking your friend about the last time he had the "front of engine" service performed. If he has had it done recently (miles and time), he can't afford to sell it to you for $1000, because he just sank $1500-$2500 into the service. If he hasn't ever had the work done, then the car is a timebomb, unsafe to drive, until the work has been completed.
red924
PostPosted: Tue Aug 17, 2004 6:36 pm    Post subject: Reply with quote
sorry to hi jack the thread, but what does the "front end service" prevent? and why is it so expensive?
1980 Red 924 CARRERA GT(rep) with custom leather interior + GT goodies!
Click on link 4 pics! http://www.924board.org/viewtopic.php?t=12422
PostPosted: Tue Aug 17, 2004 6:47 pm    Post subject: Reply with quote
I think it's to do with the timing belt. If that bugger breaks, things go pear-shaped sharp-ish
Costs a lot 'cause of the parts and labour involved, I think...
timstar924
PostPosted: Tue Aug 17, 2004 8:46 pm    Post subject: Reply with quote
cus its an interference engine, belt breaking will cause major engine damage. There are cheap 944s here too for like 3 grand cheapest but these 944s are a bad idea i would think because they probably haven't had the tuneup for a while and are due for a tuneup probably why the owner is selling. Or it is in poor condition or very high milliage and about to need a full rebuilt soon. Here you will need 6-8 grand to get a nice 944. The 1000 dollar 944 will be worse than your 924 or your friend is giving you an awsome deal which i doubt.
Eturbo924
PostPosted: Wed Aug 18, 2004 12:31 am    Post subject: Reply with quote
Very true 944s are much harder to keep up.
Issues include the timing belt, ballance shaft belts and pullies, oil and coolant mixing, leaking power steering pumps and racks, leaking and thus failing clutch slave cylinders, rubber center clutch disc failures and the like.
Anyway all other issues are common to older cars and will also be issues with a 924.
The 924 is quite bassic and does not have many of the pit falls that the 944 has. You can go early 944 like 1983 and avoid the power steering but .... the manual racks on those cars can also be issues due to owners putting tires that are to large on the front.
Just note... I had a 944 and loved it. Great engine... but I must admit I like the simplicity of the 924 when it comes to working on them.
Eric
1992 968
2003 C4S
E-mail me for parts you need!
Drive Fast!
PostPosted: Wed Aug 18, 2004 1:17 am    Post subject: Reply with quote
The 944 and 924S are basically 924 cars with improved engines, and updated interiors.
The extra horses wake up a very capable chassis that was originally delivered by Porsche with a weak engine (low horse power).
The blessing of the 944/924S, is also the curse...
The "front of engine service is required for the continued health of the engine, every three years, or 30K miles. The 944/924S engine is an "interference engine" meaning that the valves share the same space with pistons, and the continued heath of the engine relies on perfect timing of the valves.
The valves are driven by a toothed rubber belt. A second rubber belt, the balance shaft belt, resides with the timing belt and the water pump under the timing cover. The timing belt drives drives the water pump. The oil pump is driven by friction from the crankshaft pulley.
If the timing belt breaks, the valves get bent. Valves cost about $50-$75 each, depending on where you buy them. If the balance shaft belt breaks, very often, the debris drop onto the timing belt, and either jam the pulleys, or cause the timing belt to break as well. If any of the four rollers or pulleys sieze, the the balance shaft or timing belts either break of jump, bedning the valves. The water pump is not cheap. There are only two manufacturers, Porsche, and an aftermarket company named LASCO. LASCO pumps are junk. Many different companies sell rebuilts with differing levels of quality. Some people use LASCO pumps without a problem, I prefer new Porsche water pumps ($200-$300). If the water pump leaks, and if not replaced immediately, the studs that hold it in corrode and break requiring expensive methods to remove. Also coolant weakens the belts, and will cause the belts to break. If the water pump bearing siezes, the timing belt will break. If the oil sealls on the front of engine leak, the belts will weaken and break. The only way to replace them is to remove the timing cover, belts, rollers, etc...
So everything under the timing cover is related to the heath of the timing and balance shaft belts, and should be replaced between belt replacement cycles. The cost of the parts varies between $600-$1200, depending on the brand of the parts, and where you buy them. The labor to do the job is billed at 8-10 hours, and many competent shops charge $75-$125 per hour.
Many 924S and 944 cars have problems with the electric sunroofs, and parts are not cheap. The many relays in the 924S and 944 and not cheap either, they usually cost more than those used in the 924. Wiring problems are not uncommon in cars from the Midwest or East coast, and cars from everywhere suffer from Previous Owners that "hacked" the wiring for various reasons.
Here in CA, used 924S and 944 cars can be had for as little as $300-$400, but any car priced below $2000-$2500 is going to need the "front of engine service", probably some engine work (due to a broken belt or damaged head gasket), possibly some electrical work, and usually body work.
timstar924
PostPosted: Wed Aug 18, 2004 8:18 am    Post subject: Reply with quote
i'm going to buy a 944 probably sometime. I don't think if you buy a nice one for like 6-7 grand and then get the tuneup done for another 2 grand to be safe it should be fairly cheap to keep up. I think its just if you get a beater 944 your going to get fukd with repairs same with any car but of course with porsche it will cost much more. Lots of cars have interference engines and need timing belt services. i think even old honda accords are interference engines and the timing belt job cost a 1000 or so and thats a honda.
