1982Porsche924
Joined: 14 Nov 2002 Posts: 679 Location: Cupertino, CA
Posted: Mon Aug 02, 2004 4:47 pm Post subject: |
Any chance you would be able to whip out some of those fuel rails and sell them to 924 owners? _________________ 1979 Porsche 924 "S"
Engine: Euro pistons, Light Flywheel, Weber TB, Bursch Header, Cam Wheel
Suspension: Front coil-overs, adj sways, Solid bush. Thicker tors. bars, 5-bolt, BBS rims
Body: Fiberglass widebody kit, 931 Nose |
endwrench
Posted: Tue Aug 03, 2004 12:59 am Post subject: |
Maybe when summer is over. They are short here and I like to play
Todd |
1982Porsche924
Posted: Tue Aug 03, 2004 2:44 am Post subject: |
That would be great! I would have done this swap a long time ago if it I had a welder and could fabricate my own fuel rail and injector adapters. _________________ 1979 Porsche 924 "S"
CBass
Posted: Sun Aug 08, 2004 5:57 pm Post subject: |
| endwrench wrote: | Yes, It uses VE plus the size of your injectors plus RPM plus MAP load plus temp plus TPS plus several other things to calculate pulsewidth of the injectors. Most of these things are known upfront and only need to be inputed once. The VE table is your only unknown but can be roughly calculated with a few guesses. You use your O2 sensor input to plot your map. There are many tools available on the net to help with this.
I have mine pretty well roughed in and running well. I will continue to fine tune when I have a chance in order to increase my fuel milage plus fix a couple quirks.
Can't wait to see that engine swap. Sounds like it should be a very interesting endevor.
Todd |
Sounds pretty straightforward! I think I'll give it a try when I've got some more money to waste on my basketcase.
I need to ask around on the msefi.com board and see if low impedance CV Mitsubish injectors will work
As for the KL swap, I have to get myself a beater truck for work anyways, so I'm holding off until I can find an 88-94 Toyota truck with a 22RE.
I figure if the clutch assembly uses a 8-9" disc, I should be able to get away with using a 931 clutch disc with the Mazda clutch. If not, I'll end up having a custom flywheel made, and using a 911 pressure plate with a 931 disc, kinda like the Carrera GT. If I use the Porsche bellhousing, I'll cut and weld as neccessary to adapt it to the Mazda block. _________________ '81 931 in various states of assembly |
AppleBit
Joined: 16 Nov 2002 Posts: 1516 Location: Minneapolis, MN
Hugo
Joined: 11 Jun 2003 Posts: 73 Location: Uden, the Netherlands
Posted: Fri Aug 13, 2004 3:54 pm Post subject: |
| Nice work Endwrench, I'm just curious if you don't have a problem with the spray pattern of your injectors, the original injectors are very long. I work mostly on euro cars so i don't know much about mopar parts. but most of the EFI injectors i have seen are comparing to original short nozzeled. Wondering if your could use 944 injectors and fuel rail??? |
Posted: Sun Aug 15, 2004 4:10 pm Post subject: |
@ endwrench,
I dont see from your list of parts or any of your descriptions that you are using a MAF or MAS or anything like that, does the system use one or how does it get around that? as if it didnt need one and could be setup w/o one that would be very nice and easy to setup a individual throttlebody setup on the car _________________ 3 928s, |
Manning
Joined: 29 Feb 2004 Posts: 151 Location: Akron O-Hi-O
Posted: Mon Aug 16, 2004 2:18 am Post subject: |
I know TWM Induction used to make an ITB kit for the 924. They don't seem to list it anymore that I can see. Not too cheap, but it was a straight bolt on using MAP. _________________ Michael Manning
1988 924S Undergoing weight loss program |
CBass
Posted: Mon Aug 16, 2004 9:28 am Post subject: |
| Lizard wrote: | @ endwrench,
I dont see from your list of parts or any of your descriptions that you are using a MAF or MAS or anything like that, does the system use one or how does it get around that? as if it didnt need one and could be setup w/o one that would be very nice and easy to setup a individual throttlebody setup on the car |
The Megasquirt setup uses an onboard MAP sensor, you just have to run a vacuum line to the ECU. _________________ '81 931 in various states of assembly |
Posted: Mon Aug 16, 2004 3:08 pm Post subject: |
thanx cbass, that is what i needed _________________ 3 928s, |
CBass
Posted: Mon Aug 16, 2004 5:35 pm Post subject: |
I've been reading a bit in the megasquirt manual about using low impedance drivers, and having issues... Are the injectors you're using low impedance? I know the turbo 2.2 Mopars were all low imp, and alot of megasquirt users are having to wire in resistors for low impedance injectors. _________________ '81 931 in various states of assembly |
endwrench
Posted: Tue Aug 17, 2004 2:43 pm Post subject: |
Sorry I have been gone a while. Like I said summer is short here and I must play.
Hugo, I wondered if there may be a problem with this also and I have to assume the setup I am using is not "ideal" but so far I seem to be able to tune around any problems that may have arose from fuel dribbling due to short injectors. I did build my injector bungs so they allow the injector to seat on the bottem of the hole rather than the bung itself. One oddity during tuning that may be related to this is the fact I need to nearly turn off any accelleration enrichment (i.e. accelerator pump) or else I get a nasty tip in stumble at all speeds. And even weirder is the fact I need to tune in a HUGE priming pulse (like pumping the throttle on a carb) to get the car to start on the first crank no matter how warm it is.
Cbass, I have read a little about that issue also but I think it is only a problem with the guys running huge injectors for forced induction. I think anytime you get below 1.5 ms injector pulse at idle you start having problems. My injectors are a little large but have given me no problems I have identified to this point.
Lizard, Cbass is correct about the use of a MAP intead of a MAF. It is what is generally referred to as a "speed density" system. It works very well and is very tunable compared to "mass air" systems but not nearly as forgiving to performance modifications. Once a mass air is setup it will generally adapt to modifications without retuning (to a limit) where as the speed density will need to be tuned everytime you make a modification. I assume if the Megasquirt is converted to use the wide band O2 sensor it would be nearly as forgiving as the mass air systems (to a point).
Todd |
Posted: Tue Aug 17, 2004 3:27 pm Post subject: |
Todd or Cbass,
what different injectors would work with the 924/931 heads? and what exactly did you do to the head on your Todd? _________________ 3 928s, |
endwrench
Posted: Wed Aug 18, 2004 2:37 pm Post subject: |
Lizard, just about any bosch style injector that flows 19lbs or more will work. Some with extended nozzels might give a better spray pattern but I am not sure what uses these other than 3.0 L Nissans. Mine are not extended and I haven't detected any problem yet.
Here is a table of injectors and there flow rates just to give you an idea of what is available. If you look towads the bottem of the page you will find a chart on HP per cylinder versus flow rates. 19lbs injectors from a 3.0L Taurus will easily support 125HP.
Not sure what you are asking about my head modifications. Only thing I had to do was build some injector inserts that screwed in place of the stock ones.
Todd |
CBass
Posted: Wed Aug 25, 2004 2:54 pm Post subject: |
Here's that link without the extra URL on the end
http://users.erols.com/srweiss/tableifc.htm
My first goal with this swap is reliability, performance tuning will come later. If the low impedance injectors work well, I'm happy.  _________________ '81 931 in various states of assembly |
