My ride
PORSCHEV
PostPosted: Mon Aug 02, 2004 10:48 am    Post subject: My ride Reply with quote
1978-#53 "D" track racer.
Neil924
PostPosted: Mon Aug 02, 2004 10:01 pm    Post subject: Reply with quote
You have the best looking car in this thread!
Very nice indeed. Could you list the specs for everyone?
PORSCHEV
PostPosted: Mon Aug 02, 2004 10:17 pm    Post subject: Reply with quote
By spec, I assume you mean engine specs.... The engine is out of a 1967 corvette 327 with the "camel hump" heads. 1.94 intake. Ported and polished. Has comp cam, roller tip rockers on the valve train. The block was bored out to the max .60 over with new flat top pistons , rings bearings and such. 11:?:1 can't remember right now. Cloyes double timing chain. Has a Holly 670 strret avenger card with the Holly 850 cfm air cleaner.
Desk top dyno @ 346 hp and 330 ft/lbs of torque...but I think that is a bit generous!.....any thing over 300 will be PLENTY
Warwick
PostPosted: Mon Aug 02, 2004 10:45 pm    Post subject: Reply with quote
Nice! Best I've seen so far!
-78 924 NA
7x17 rims et 35 with 9 mm spacer front 34 mm rear.
Working on 5-bolt swap and supercharger kit.
Neil924
PostPosted: Tue Aug 03, 2004 11:19 am    Post subject: Reply with quote
hehehehe you said hump!
It looks nice, it seems to be dripping grunt and is plain ol' cool!
In the words of a science geek somewhere... neato!
wdb
PostPosted: Tue Aug 03, 2004 12:11 pm    Post subject: Reply with quote
i heard or read somewhere that the chevy camel hump heads were performance heads machine to loose extra wieght , thats where the camel shape from . and there more sensitive to cooling problems . being thinner in places it warps/cracks easier than the stock heads . just a heads up ,so you know .
Llamaguy
PostPosted: Tue Aug 03, 2004 12:12 pm    Post subject: Reply with quote
makes me want to abandon this only timing belt mess and put a 302 out of a mustang in her, hehe
1987 924S Guards Red
1997 Suzuki Tl1000 Supersport
PORSCHEV
PostPosted: Tue Aug 03, 2004 9:18 pm    Post subject: Reply with quote
If I were to do it agian....I would only go with an LT1 or a fuel injected 5.0. You could find a 5.0 just about anywhere....LT1' s are bit more scace and pricey.
wdb
PostPosted: Tue Aug 03, 2004 10:14 pm    Post subject: Reply with quote
I'm not sure if I should supercharge and stroke the 924 to 2.3L , that would give around 250 HP ,or go with the ford all aluminum 4.6L 32 valve v8 from the 97 and newer lincolns . thats what fords putting into the mustang cobra's , with a supercharger of course . but the 4.6l is wider than most v8's because of the dual over head cams , so it might not fit ,or would require serious alterations . if I hit the lottery, I'll go with the latest version of the ford motor . 420 HP 5.0
http://www.fordmuscle.com/archives/2003/11/cammer/index.shtml
Llamaguy
PostPosted: Wed Aug 04, 2004 11:29 am    Post subject: Reply with quote
they're not 5.0s anymore, they have been 4.6 since '96 except for the 2000 Cobra R
wdb
PostPosted: Thu Aug 05, 2004 9:01 am    Post subject: Reply with quote
yeah ford turned the 2000 Cobra R motor into a crate engine check the link in theprevious post to see 3 versions that are available .
PostPosted: Thu Aug 05, 2004 5:05 pm    Post subject: Reply with quote
You could try this one...
http://www.fpv.com.au/index.asp?link_id=2.180
5.4-litre (~330ci), all-alloy, quad cam, ~400hp
