Magnus K
Joined: 25 Oct 2003 Posts: 151 Location: Linkoping, in Sweden
Posted: Thu Apr 29, 2004 3:21 pm Post subject: Intermittent fuel pump cut-outs? |
Hi!
Started the "RedThingey" yesterday and had some problems with the fuel pump. It seems I got problems somewhere around the additional fuse board, I don't seem to get any electrical power to the fuel pumps? The problem is intermittent, just comes and goes??
[Rants&Ramblings]
When I do have fuel pressure the car starts up and runs just fine! It's not been started since November and still the battery is holding enough power to crank the enginge many turns while we were trying to find the fuel problems!
[/Rants&Ramblings]
Regards
Magnus _________________ Another curious Swede...
Asleep in Sweden, Europe, when you US guys are awake... |
gwsg
Joined: 03 Nov 2002 Posts: 160 Location: Melbourne Australia
Posted: Thu Apr 29, 2004 4:48 pm Post subject: |
Try checking the wires that connect to the top of the relay plate that the fuel pump relay sits in. If you have been leaking any water in there they are likely to be green and corroded causing an intermittent current flow.
cheers
Geoff _________________ My 80 924 loves me. |
Magnus K
Posted: Thu Apr 29, 2004 7:08 pm Post subject: |
Thanks, Geoff! I think that could be an issue here, this car has taken in loads of H2O...
Will look at that tonight!
Regards
Joined: 29 Jul 2001 Posts: 9116 Location: Royal Oak, MI, USA
Posted: Thu Apr 29, 2004 11:58 pm Post subject: |
Yes, I had exactly this problem very bad on my 82 931. I ended up cutting the wires off the #2 fuse and wiring in 2 other fuses, modern blade-style fuses, to fix it for good. The new fuses are in weatherproof enclosures!  _________________ Vaughan Scott
Magnus K
Posted: Fri Apr 30, 2004 1:27 am Post subject: |
OK, I'll take the whole thing out and have a look at it... Hopefully I will remember which cable goes where... (Digital camera = blessing in this case?)
Thanks!
Roger
Posted: Fri Apr 30, 2004 9:37 am Post subject: |
I didn't check the wiring diagrams but doesn't the aux fuse pannel get power from the main pannel? If so it could be the relay that is causing the readings. Try jumpering the relay pannel and see if the readings change. _________________ 1981 924 NA
