Tube behind Snailshell???
jgolfer
PostPosted: Fri Mar 19, 2004 10:11 am    Post subject: Tube behind Snailshell??? Reply with quote
I have a foot long tube that is attached to the back of the snailshell, it has been the cause of a rattle. I tightened the bolt and it stopped for a while, now I hear it again. Can I remove this thing or not?
Peace
John
PostPosted: Fri Mar 19, 2004 10:57 am    Post subject: Reply with quote
this stell tube is mounted onto the back of the tranny so in the event of a MAJOR rear ending the gas tank wont be broken open, you can remove it w/o any consiquences just dont get rear ended badly,
3 928s,
jgolfer
PostPosted: Fri Mar 19, 2004 12:21 pm    Post subject: Reply with quote
Thanks Lizard, have you removed yours? It is just so annoying to hear that thing vibrate, I thought if I could wedge a piece of rubber within the tube somehow to cushion it...I don't know, I quess I will just take it off.
Peace
J
mrgtturbo
PostPosted: Fri Mar 19, 2004 12:48 pm    Post subject: Reply with quote
If you get rear-ended real hard in one of these cars you're probably gonna die anyway.... might aswell go out in flames.
81' 931
PostPosted: Fri Mar 19, 2004 1:03 pm    Post subject: Reply with quote
jgolfer, I do not have it in my car, mine didnt rattle, although if the bolts are tight and it is still rattling then you need to inspect tranny and engine mounts
3 928s,
PostPosted: Fri Mar 19, 2004 10:48 pm    Post subject: Reply with quote
My impression of that tube was that it was just a mass hung on the back to eliminate a vibratory mode that would be objectionable (by changing the resonant frequency). Ran fine without it.
CMXXXI
PostPosted: Sat Mar 20, 2004 4:29 am    Post subject: Reply with quote
What steel tube behind the snailshell?!? The only thing attached to mine is the hanger "arm" that supports the muffler. Is this a US/Canadian-spec car addition?
'79 Eurospec 931
jgolfer
PostPosted: Sat Mar 20, 2004 4:55 am    Post subject: Reply with quote
Well I took it off, and the difference is great! No More Noise from the rear!!!
Peace
J
John Brown
PostPosted: Sat Mar 20, 2004 5:47 am    Post subject: Reply with quote
It is in fact a 'crash' part extending behind the snailshell transmission. If you look on the forward wall of the spare tire well you'll find a matching casting (I think it was) bolted to the wall. Provides a strong solid impact area to the 'tube'. If the plate is missing look for the 3 bolt holes that held it.
Can't imagine what would rattle.
John
80 931 - #931 44Cup
99 Escalade - tows track cars
PostPosted: Sun Mar 21, 2004 2:59 pm    Post subject: Reply with quote
John you are correct, it was cast aluminum
3 928s,
Kenodog
PostPosted: Mon Mar 22, 2004 5:38 am    Post subject: Reply with quote
Took mine off but then put it back on.Don't wan't to be driving a Pinto man.
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
goc931
PostPosted: Mon Mar 22, 2004 7:22 am    Post subject: Reply with quote
Yeah, must be a US/Canadian option.
Mine is like yours, support för muffler.
Best regards
Goran
Porsche 924 -83, Race car
132hp, 950kg w/o driver
John Brown
PostPosted: Mon Mar 22, 2004 9:08 am    Post subject: Reply with quote
Very likely is a US and whoknowswhereellse part; as it is only for crash.
John
80 931 - #931 44Cup
sandgroper
PostPosted: Mon Mar 22, 2004 9:31 am    Post subject: Reply with quote
no anti pinto device on my ROW 80 turbo
numbbers
PostPosted: Fri Mar 26, 2004 11:21 am    Post subject: Reply with quote
Yep, probably necessary to pass US crash test standards, like the extended bumbers.
