cleethorpes
Joined: 26 Jan 2004 Posts: 186 Location: cleethorpes (oddly enough!)
Posted: Sun Mar 07, 2004 1:11 am Post subject: metalic noise?? |
| After hard accelerating, when I lift off the pedal there is an very rattley noise. Is this normal, as I have had cosworth turbo's etc and never experienced a noise quite like it.?? |
Posted: Sun Mar 07, 2004 1:39 am Post subject: |
probably a broken wastegate hanger. _________________ 3 928s, |
cleethorpes
Posted: Sun Mar 07, 2004 1:42 am Post subject: |
figured it was from that area, not too big a job if that is the case.
Bloody annoying though..nice whistle under acceleration..then lift off...rattle chatter rattle...bit rubbish sounding!
Will deal with the problem when I can get hold of some 8mm studs to replace the missing ones! |
Posted: Sun Mar 07, 2004 2:06 am Post subject: |
getting the wastegate bracket replaced is HARD with the engine in _________________ 3 928s, |
dpw928
Posted: Sun Mar 07, 2004 4:31 am Post subject: |
It could also be the timing belt cover (if installed) rattling against the pulleys when the engine shifts. BTDT
78 928 5 sp Silver
78 928 AT Euro Black |
cleethorpes
Posted: Sun Mar 07, 2004 5:21 am Post subject: |
| The guy who had the car before me said he'd recently fitted a new wastegate, so he may have left a few things loose I guess. After all, he didn't bother to replace the missing exhaust studs so maybe his workmanship was not up to scratch. |
