ljd 924SE
Joined: 04 Dec 2003 Posts: 30 Location: Tallahassee, FL
Posted: Mon Mar 01, 2004 3:24 am Post subject: |
my car sometimes had starting issues due to a bad ground preventing any juice from getting to the starter. i'd get out of the car, wiggle the cable a little and she'd start right up. it's the negative cable coming off the battery, grounding on the bellhousing. the problem was permanently solved by purchasing a ground cable kit from iceshark which is available at www.gururacing.net for $44. now, if your car is turning over and won't start, i don't know what to tell you. but if it's not, try wiggling that ground cable and maybe you'll have the problem solved. _________________ '88 924S Sport Edition
http://www.cardomain.com/id/ljd924se |
