garyj
Posted: Fri Feb 27, 2004 4:24 am Post subject: hatchback help |
| hey my hatchback wont open on the right side. i turn the key and the left side pulls up a little and the right side stays own...any one have an idea whats wrong??? help me! |
Posted: Fri Feb 27, 2004 4:37 am Post subject: |
try pressing down on the side that is not releasing then turn the key and then lift,
they pin could be adjusted 2 short and is not allowing for the relaese to release _________________ 3 928s, |
Posted: Fri Feb 27, 2004 4:43 am Post subject: |
You might try pushing down on the side that won't open while turning the key. If still a no-go you can crawl in from the front, pull down the carpeting at the rear, and see what you can see. There'll be rods from the lock out to each latch. The rod for the one that's not opening might be disconnected or out of adjustment.
Another possibility is you have pressure in the shock on the side that pops up, but no pressure in the other sides'. _________________ "..it's made in Germany. You know the Germans always make good stuff."
