Were any 924's carb cars
blury
PostPosted: Fri Feb 06, 2004 3:26 am    Post subject: Were any 924's carb cars Reply with quote
Were any carbruated or were they all that damn injection sustem.
Other questions. These injection system seem alot like the Benz. Can you trasplant any parts. Are the adjustable in any way.
Can they be converted to carbs. Ive had with my S and want down size a bit.
Polish your apc banner and shut up
PostPosted: Fri Feb 06, 2004 3:47 am    Post subject: Reply with quote
all 924/924S/944/968 were a form of fuel injection, none came from the factory with carbs, yes you can convert if your heart is set on it though
what year is your car and model?
3 928s,
leadfoot
PostPosted: Fri Feb 06, 2004 7:52 am    Post subject: Reply with quote
only D production race cars had carbs, but this type would probably be overkill on a street car unless your using engine management and are leaving yourself some room for further modifications to the engine such as a stroker kit and higher compression pistons for example...leadfoot
PostPosted: Fri Feb 06, 2004 8:24 am    Post subject: Reply with quote
Leadfoot I dont think the 924 D prod had carbs it had individual throttlebodies with fuel injection iirc
3 928s,
Vince Ponz
PostPosted: Fri Feb 06, 2004 10:50 am    Post subject: Reply with quote
Pictures of one of the 16 or so D Prod cars are on the way to Mr. Lizard.
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock
numbbers
PostPosted: Fri Feb 06, 2004 11:03 am    Post subject: Reply with quote
Actually, the CIS system that your 924 has was one of the most dependable and simple fuel injection systems ever designed. The problems usually arise from previous owners (or present owners) who want to jump in and start adjusting things before they have properly diagnosed the problem. Most of the problems can be traced to rubber parts that have given up, causing vacuum leaks. And once you start adjusting to compensate for the vacuum leak, you will play hell getting everything back to specs.
blury
PostPosted: Sat Feb 07, 2004 7:18 am    Post subject: Reply with quote
Well im looking at getting rid of 924S and getting a regular one. But i would like some speed out of it. That means upgrading is important. Now i know the CIS is reliable but i need to be able to adjust and upgrade it if neccasy prefferably without alot hassel. I like to go to the track every now then and blast through curves so i would like some additional HP. I like my S but maintanance is just to much. Its fun but it seems like everytime i drive it im bringing it closer and closer to death and the recent events with it just made my notion of going to regular 924 seem alot better than before.
