New 924 Woe.....Help?!?
Goto page Previous  1, 2
PostPosted: Thu Feb 05, 2004 8:11 am    Post subject: Reply with quote
look on the bright side you didnt tear it half apart then realize it,
3 928s,
Richard
PostPosted: Thu Feb 05, 2004 2:14 pm    Post subject: Reply with quote
Why can't you drill a new dowel hole in the end of the crank and make a new timing mark, say 180 from the other one. Use lock-tite blue on the main bolt.
Hotrod2go
PostPosted: Fri Feb 06, 2004 1:31 am    Post subject: Reply with quote
Actually the thought had crossed my mind. I was a bit concerned on the clocking, (critical)...
Thanks!
"Get In, Sit Down, Hold On AND SHUTUP!"
Hotrod2go
PostPosted: Fri Feb 06, 2004 2:08 am    Post subject: Reply with quote
...another thought/question... Is there a balance issue if I rotate the pulley 180 degs? Should I drill new holes 180 degrees off on both parts?
Thanks, Phil
PostPosted: Fri Feb 06, 2004 2:23 am    Post subject: Reply with quote
drill the holes 180 deg in BOTH pieces
3 928s,
Page 2 of 2
