ATTN: someone who's done V-8 conversion
OR_Sunset
PostPosted: Fri Jan 23, 2004 5:13 am    Post subject: ATTN: someone who's done V-8 conversion Reply with quote
I know this has probably been covered, but other than fabricating the appropriate engine mounts, how does one mate a small v-8 to the torque tube in the 924?
Obviously, the bellhousing requires modification, and the clutch will be upgraded... but what needs to happed between the rearmost portion of the crankshaft in the center of the flywheel and the driveshaft?
Giving this serious thought. I can pick up a decent v-8 block up around here for almost nothing, and spend less than $1000 for a stroker rebuild kit. I figure $2000 to complete the engine. How much should I plan on spending on mounts and the drivetrain?
I am trying to figure out if the conversion itself can be done for less than $3000.
82 924 N/A -
9.3:1 CR Pistons, Dual Webers, Stage 2 Cam.
4-1 Headers, DynoMax exhaust, Monza tips.
MSD 6AL Ignition, 944racing short shift kit.
Through hood cold air intake with scoop, K&N.
Silver/Blue.
Mikri184
PostPosted: Fri Jan 23, 2004 6:30 am    Post subject: Hey Reply with quote
This is a forum for this down at the buttom of the page. I hate to think after all that work you will ditch the 2.0 out of your car, but hey a V-8 would be cool especially with your hood scoop.
Can I have you old engine and all the goodies
Life is to short to be looking for something?
OR_Sunset
PostPosted: Fri Jan 23, 2004 7:24 am    Post subject: Reply with quote
Yeah... I looked through the Engine Swap forum, but there were no specifics or pics... just alot of hypothetical stuff.
I just can't get over the fact that the original engine broke down b/c of bad bearings, loss of oil pressure, the replacement engine worked well for 2000 miles, and now needs a rebuild.... I want something RELIABLE.
My Camaro went over 250,000 miles on the original engine with just a minor rebuild (new bearings and seals) at 150,000. Total cost for the rebuild: $500.
The *$!**!* Porsche went 2,000 miles AFTER a $1500 rebuild and now it needs another one.
I am beginning not to like these little 2.0L 4s. I have two thoughts: a 1.5 liter DOHC twin turbo to spin the heck out of like an F-1 car, or a nice old reliable V8.
If I end up doing either, I will have a garage sale.
For now, I am getting to know my new Neon... and I must say, it is almost as fast as the Porsche... but it feels like a toy. The 2.0L 4 in the Neon is smooth and quiet, 16v, and torquier than the Porsche motor. The driving experience just isn't there, though.
82 924 N/A -
Silver/Blue.
PostPosted: Fri Jan 23, 2004 7:27 am    Post subject: Reply with quote
so OR I guess you are not interested in the block we talked about earlier
3 928s,
OR_Sunset
PostPosted: Fri Jan 23, 2004 9:42 am    Post subject: Reply with quote
Actually, I am interested in anything that will get my car back on the road.
I am looking into what it would take to have my pistons installed in that block with new rings, and have a machine shop do the assembly... that way everything should be good.
Just looking at lots of options right now...
82 924 N/A -
Silver/Blue.
Mikri184
PostPosted: Fri Jan 23, 2004 9:44 am    Post subject: 2.0 block from canada Reply with quote
Seems kind of pricey to ship a block from canada to OR Ouch. I would gladly help you ship it from here if you brought it down
PostPosted: Fri Jan 23, 2004 11:40 am    Post subject: Reply with quote
I was going to be bringing it across the border for him make a road trip outta it
3 928s,
Mikri184
PostPosted: Fri Jan 23, 2004 6:33 pm    Post subject: road trip Reply with quote
That would be cool You could crash at my place while you wait for lizard to cross the border. heck you could rummage my parts too
leadfoot
PostPosted: Tue Jan 27, 2004 5:44 pm    Post subject: Reply with quote
beario was selling a bellhousing conversion for a 3500 rover V8, and his friend was also doing a conversion for a 4.7 ltr version as well.
the rover engines i believe are alluminiun and they are carb based.
you would probably need to have a fuel regulator for low psi but apart from that, i think the 3500 was putting out around 180bhp.
if you include heavier springs in the struts just in case and shot peen the transmission and drive shaft you could make a stonking motor, then add some porting and possibly engine management.
a mini 928 rocket...
leadfoot
CBass
PostPosted: Thu Jan 29, 2004 1:15 am    Post subject: Reply with quote
The Rover V8 is a much better choice than a domestic smallblock if you want to preserve the sports car handling of the 924. It weighs a little less than the 924 engine, IIRC.
Adie on rennlist is running 10 second 1/4 miles in her nitroused Rover V8 924, so it's not like they don't make enough power
Drag racers in England have been making good power out of these little smallblocks for years, and they are a pretty straight forward swap into a 924.
OR_Sunset
PostPosted: Fri Jan 30, 2004 6:26 pm    Post subject: Reply with quote
Thanks for all the tips. I will look into the availability of Rover engines here...
but regardless of whether I have the stock engine repaired or put a different one in, it looks like it will be awhile. I have too much other stuff on my plate right now.
IT SUCKS!!!! I WANT TO DRIVE MY PORSCHE!!!
sorry... those damn withdrawls from not being able to drive a german sports car.
82 924 N/A -
Silver/Blue.
CBass
PostPosted: Sat Jan 31, 2004 12:37 am    Post subject: Reply with quote
Adie sent me a whole bunch of pics from her swap, as she did it, so there are some really good pics. I'll email you the links.
