jamez
Joined: 03 Nov 2002 Posts: 401 Location: Chehalis, Wa
Posted: Tue Dec 16, 2003 1:30 pm Post subject: '96 Corvette motor into '77 Porsche 924 |
Well folks the car is almost ready to be put back on the road, I just gotta tie up a few loose ends, hopefully before Christmas.
The engine is installed, has been started in the car and spun the back wheels with the car jacked up, I haven't actually driven it yet because I don't have the clutch hydraulics all put together yet. I'm putting the battery in the back of the car to try and get some weight off the front. 350# springs have also bee installed in the front.
When I started this project almost a year ago, I was planning on putting everything on a webpage, but I haven't had the time. If you think you have the knowledge and skill to do a project like this, you're probably right. But if your not sure, then I wouldn't attempt it.
Obviously every component is custom built, but the main parts are the motor mounts and drive shaft/clutch system.. once you get that figured out everything else is trivial, but even the trivial things can be a son of a bitch to figure out, and you can figure on every little part you need costing at least $100
Anyways, I'll try to post a few pictures soon. later
-Jamez |
PORSCHEV
Posted: Mon Dec 22, 2003 10:41 pm Post subject: |
I am soo jealous .....I haven't even started mine yet! But congrats just the same. Did you manage to have the hood close in stock form with the injection type engine? So hurry the hell up with the pictures already!! _________________ 1976 924
1978-#53 "D" track racer. |
Posted: Sat Dec 27, 2003 8:14 am Post subject: |
Jamez sent me 2 pic. to post. Motor looks good. Check out his
headlight mod. pretty trick eh.
 _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Sat Dec 27, 2003 9:51 am Post subject: |
hmm, those headlights are not my style if you could make a fibeerglas mold that holds the projection lights I think it would be better _________________ 3 928s, |
turbobob9242
Joined: 08 Feb 2003 Posts: 138 Location: Hinckely Ohio
Posted: Sun Dec 28, 2003 5:01 am Post subject: RE V-8 swap |
Looking good!!
Manual or power brakes?? _________________ Bob Ward
80 9214 turbo, w 5.3 LS V8 |
Posted: Sun Dec 28, 2003 6:41 am Post subject: |
looks to be manual brakes _________________ 3 928s, |
