Luguts wanted
PostPosted: Wed Mar 26, 2003 3:12 pm    Post subject: Luguts wanted Reply with quote
Wanting to buy a set of used lugnuts for my fuchs. Open
racing lugnuts or original.I cant find any close to where Im at. Thanks
PostPosted: Thu Dec 18, 2003 11:34 am    Post subject: Reply with quote
Im looking for a set of lugnuts still for all 4 wheels fuchs.
PostPosted: Fri Dec 19, 2003 12:40 am    Post subject: Reply with quote
last set I saw was on e-bay a set of 20 went for $70 +
3 928s,
crazyinkc
PostPosted: Fri Dec 19, 2003 1:34 am    Post subject: Reply with quote
Joe,
I should have a set. How does $40 plus shipping sound? Let me know.
PostPosted: Fri Dec 19, 2003 1:44 am    Post subject: Reply with quote
Are they black? -or silver?
Doesn't matter actually - Joe paints everything.
PostPosted: Fri Dec 19, 2003 2:10 am    Post subject: Reply with quote
they will be pink soon
3 928s,
crazyinkc
PostPosted: Fri Dec 19, 2003 2:49 am    Post subject: Reply with quote
They are a faded black. I figured Joe would paint them yellow to match this wheels but Lizards idea of pink is good. Maybe a lime green would be nice. Just kidding Joe.
PostPosted: Fri Dec 19, 2003 3:06 am    Post subject: Reply with quote
hey Joe, if you need a set of lugs what r u using to hold the wheels on now, zap straps?
3 928s,
PostPosted: Fri Dec 19, 2003 3:12 am    Post subject: Reply with quote
Here's Harbor Freights' lug nut finish protecting socket set:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40036
You get the 19mm size that you need plus two more that you don't for half the price of one 19mm at Performance or Tweeks. -Or for about the same price (as one at Tweeks or Performance) you can have seven from HF: http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40035
PostPosted: Fri Dec 19, 2003 5:33 am    Post subject: Reply with quote
Great whooaaa waite hold on. Lugnuts are spendy
way to spendy.
PostPosted: Fri Dec 19, 2003 6:18 am    Post subject: Reply with quote
yes the magnisium ones are, the steel ones are abit cheaper but not much,
and shouldnt this be in the parts wanted section moderators?
3 928s,
PostPosted: Fri Dec 19, 2003 10:16 am    Post subject: Reply with quote
Im gonna be wanting to take the car out on the track
after I join the porsche club. To be able to you have to
have steel lugnuts I believe. What they called? Acorn nuts?
the mating surface between the bottem of the nut and hole
on the rim is special so I guess all lugnuts wont fit.
PostPosted: Sat Dec 20, 2003 1:44 am    Post subject: Reply with quote
I have never heard of that, the PCA up here says the factory magnisium nuts are fine,
3 928s,
PostPosted: Sat Dec 20, 2003 3:05 am    Post subject: Reply with quote
Yes, I think it is called an acorn seat - rounded (ball) seat, instead of a straight taper (which is more common).
Paragon sells the steel nutz, about $1USD each IIRC. It's actually factory parts. Hell, try a dealer! You never know...
PostPosted: Sat Dec 20, 2003 3:25 am    Post subject: Reply with quote
I have a vague recollection of reading somewhere that steel lugnuts are for use only with steel wheels and mag lugnuts with alloy wheels.
It's also important that the curve of the mating surface between lugnut and wheel are matched, especially with alloys.
