Matias Guest
Posted: Wed Dec 05, 2001 2:00 pm Post subject: |
Today I was returning home when I realizaed that my fuel reserve light has been on for a lot of time. So I´ve decided to stop in the gas station and refuel. A couple of miles after my tank was filled my car couldn´t idle and feel´s like the mixture is rich as hell at low RPM´s. Above 4000 RPM the engine works fine, but it doesn´t idle and throw´s black smoke, through the exhaust.
Any ideas? The O2 sensor has been unpluged for a while, could this be the cause??
Today the car has to bee at idle for too much time, could these affect?
Please help!!!!!
numbers Guest
Posted: Tue Dec 11, 2001 7:42 am Post subject: |
| Sounds like you are running very rich. I would suspect a large vacuum leak. Check all of the rubber elboes on your vacuum pipes and all of the vacuum hoses. |
