Cooling fan wont stop.
Jato
PostPosted: Sat Oct 18, 2003 5:51 am    Post subject: Cooling fan wont stop. Reply with quote
I have a 1987 924S and the fan wont stop running somtimes. so lastnight it did not stop and today my battery is dead. What can i do to fix this? if anything?
Thanks for the help,
Jeff
Which car to buy?
PostPosted: Sat Oct 18, 2003 6:49 am    Post subject: Reply with quote
If you car is not running hot when you park it. Take the wire off of it untill you fix it
kabok
PostPosted: Sat Oct 18, 2003 8:39 am    Post subject: Reply with quote
What's happening is your temperature sensor is stuck in the closed position, sending current to the fan motor all the time. Replace the sensor. Until then put in a toggle switch, so you can make it run manually.
Roger
PostPosted: Sat Oct 18, 2003 10:54 am    Post subject: Reply with quote
The temp sensor is a good place to start, but if the fans stay on after the ignition is turned off and the temp guage is below the half way mark. Then you also need to check the resistor.
1981 924 NA
PostPosted: Sat Oct 18, 2003 11:21 am    Post subject: Reply with quote
The thermo fan switch going bad will cause the fan to run all the time. It would run at high speed when the ignition is on and at low speed when the ignition is off.
If the fan runs at high speed all the time, whether the ignition is on or off, then the cooling fan relay is bad.
Jato
PostPosted: Sun Oct 19, 2003 5:57 am    Post subject: Reply with quote
thanks for the help everyone i think i figured it out but does anyone know were i can find a wiring diagram for the cooling system or tell me where the relay for the thermo switch is
thanks again
PostPosted: Sun Oct 19, 2003 10:07 am    Post subject: Reply with quote
The thermo switch is on the driver's side of the radiator (on US cars), just below the top hose.
Make sure your wiring is not shorted at the switch, sometimes the insulation gets worn allowing the wires to touch.
Roger
PostPosted: Mon Oct 20, 2003 8:55 am    Post subject: Reply with quote
Here is a link for the 1984 diagrams on Pelican. The Haynes manual has them also.
http://www.pelicanparts.com/944/electrical/944_electrical_diagrams.htm
1981 924 NA
