Car won't start
Goto page Previous  1, 2
PostPosted: Tue Sep 23, 2003 9:21 am    Post subject: Reply with quote
Man, I was willing to bet on a bad ground... Well, replace it anyway... the engine to firewall ground.
78 924 N/a
PostPosted: Tue Sep 23, 2003 4:27 pm    Post subject: Reply with quote
I don't believe in "snake oil mechanic-in-a-can".
1978 924 n/a
Mikri184
PostPosted: Tue Sep 23, 2003 5:14 pm    Post subject: A cleaner, not snake oil Reply with quote
I don't use snake oil either. But needed to clean this car out after sitting eight years. Things weren't flowing properly/ The seafoam. Is a cleaner thats all says so on the can. That's why it was suggested. I was concerned about the valves, after have bad injectors seals and out side of tearing the head down. Which wasn't an option. I needed something that could do the cleaning with out further gumming up the system, Seems to have worked. And I would recomend it. Anyways few more adjustments car is still running great up to a 100 mph on the freeway no problems. By the way I did make sure the ground strap was in good order and clean. Thanks
PostPosted: Tue Sep 23, 2003 10:33 pm    Post subject: Reply with quote
Um, no, um, you weren't listening to me.
REPLACE IT!!!
I don't care if you polish it with a friggen dremel; it's still not as good as a new ground strap.
Mikri184
PostPosted: Wed Sep 24, 2003 4:04 am    Post subject: hmmm Reply with quote
Your right there on not as being as good as new. Try to get one this afternoon. Did replace the battery wires though with new positive and negative. Thanks
Page 2 of 2
