Do the math
teo
PostPosted: Sat Nov 24, 2001 3:49 am    Post subject: Reply with quote
Hey guys,
I just did some calculations on the different types of 924 transmissions, speed as a function of engine rpm - wheel size - gear ratios.
There are some interesting results, and if the calculations are right and the type 016Z is the one also known as the "snailshell", now I know why everyone likes them.
Would you check it and tell me if I made some mistake in it?
http://web.matavnet.hu/teoinfo/p924/transmission.htm
Teo
[ This Message was edited by: teo on 2001-11-24 04:51 ]
teo
PostPosted: Sat Nov 24, 2001 7:05 pm    Post subject: Reply with quote
Hmm, so I couldn't get it right for first time, now it's fixed.
Teo
cs
Guest
PostPosted: Sat Nov 24, 2001 7:07 pm    Post subject: Reply with quote
nevermind, i see you've already figured it out.
engine rpm/(gear ratio*axle ratio)= wheel rpm
wheel rpm*circumfrence of tire=ft/min
ft/min * 60/5280= miles/hour
example: numbers are just estimates of what i remember, in first gear at 6000 rpm
6000/14=428.571
428.571*6=2571.43
2571.43*60/5280=29.2208mph
[ This Message was edited by: cs on 2001-11-24 20:08 ]
Joes924
Guest
PostPosted: Sun Nov 25, 2001 4:25 am    Post subject: Reply with quote
Thats pretty impressive kind of ..
larso
Guest
PostPosted: Mon Nov 26, 2001 4:35 pm    Post subject: Reply with quote
The turbo snailshell is the only tranny that makes the 931 look fast on paper, since it goes to 60 with the old rev limiter in second....
PostPosted: Tue Nov 27, 2001 2:54 am    Post subject: Reply with quote
I hate to break your heart, but Jon did this a while ago in a spreadsheet:
http://www.924.org/Downloads/Downloads.htm
It's the one labeled tranny ratios...
teo
PostPosted: Tue Nov 27, 2001 4:07 am    Post subject: Reply with quote
No problem, a few minutes ago I've even found it on my HDD saved from the site
So, before I start doing something I should check:
1: http://www.924.org
2: my own computer
3: the entire internet (I've found quite a few sites with rpm/speed calculators, of course only after I've done mine)
Anyway, I'm just learning this automotive stuff, and a little excerise will not hurt... even if it's only the theoretical side.
Teo
