Wiz-PORSCHE-924
Joined: 06 Nov 2002 Posts: 214 Location: Douglassville PA
Posted: Thu Sep 18, 2003 11:35 am Post subject: Do I have a Performance Part and not know it ??? |
| The Throttle body on my 78 on the side it says REDLINE and WEBER on the top. Is this OE ?? |
Zuffen
Joined: 31 Jul 2001 Posts: 1427 Location: Owasso, Oklahoma 74055
Posted: Thu Sep 18, 2003 12:06 pm Post subject: |
no it is aftermarket and somewhat sought after but not necessarily rare.... _________________ Bob Dodd - 924turbo@cox.net
931 1982, 944 1982 euro, 924S 1988SE, 93 968 tip 06 Silver Cayenne S, 06 Black Cayenne S
I have Way too many cars, parts for the 931,944 and 951 |
Wiz-PORSCHE-924
Posted: Fri Sep 19, 2003 11:56 am Post subject: |
| So Who made it and is it any better? How ? |
78 924 N/a
Joined: 20 Mar 2003 Posts: 769 Location: Pacific N.W.
Posted: Fri Sep 19, 2003 12:34 pm Post subject: |
Weber. Wanna sell it? _________________ 1978 924 n/a |
jpab924
Joined: 03 Nov 2002 Posts: 1538 Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
Posted: Fri Sep 19, 2003 1:59 pm Post subject: |
The Weber t-body is a single big bore.
I don`t know the exact measurements, but it is plenty bigger than the stock double barrel t-bodies.
Theory is, a bigger bore means less restriction. So, you get more air into the cylinders. You can run richer, and pack in more of a "charge" into the cylinders. This means more power.
I haven`t seen any proof that this t-body does any good. Other than a few testemonials I`ve read here. |
78 924 N/a
Posted: Fri Sep 19, 2003 2:12 pm Post subject: |
Its been said by some to have a somewhat improved throttle response. Peak gains are said to be non-existent, as is with almost all bolt-ons.
I also have not ever seen any "real" tests done with a Weber tb.  _________________ 1978 924 n/a |
Roger
Posted: Sat Sep 20, 2003 2:00 pm Post subject: |
Best I can tell is that the larger throttle body yealds about 3-5 hp at best but you sould have better throttle response. _________________ 1981 924 NA
Posted: Sat Sep 20, 2003 3:04 pm Post subject: |
Is that so Roger [didnt I get you a pet cd]
Heres a testimonial [a short one]
Whats cool is you can get on the power band and with other mods
you can have some fun by opening it real fast it gives pretty quicke response.
Away from that I can see where right after my paint job
is done Im gonna [maybe] pull the motor and up th cp
[10-1] have the head checked for straightness figure if
I can set it up for quicke turn out from the machine shop
that would work..and while I waite [I doute it though]
replace the 1 st gear synchro 016z while there do them
all if they need it for me though its best if I buy a used
one for $300.00 and just take my time and install it
when its finished. The one I have is fine it just doesnt
like to go into 1st when rolling.
Hold on to the TB I got mine from Jpab in Indiana.
who should of kept it. I like it alot. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Roger
Posted: Sun Sep 21, 2003 2:13 am Post subject: |
Thanks Joe, I do appreciate it but I never got it to work, oh well. I did get a whole bunch of reference and tech stuff though. I did not mean to make it sound like the larger throttle body was not worth it. I like the idea. Its just not a huge HP gain. _________________ 1981 924 NA
