turbobob9242
Joined: 08 Feb 2003 Posts: 138 Location: Hinckely Ohio
Posted: Wed Aug 20, 2003 10:43 am Post subject: RE Phantom grip LSD |
HI everyone.
I sent an email to the Phantom grip LSD people ad it looks like a nice alternative to the more expensive Quaiffe or Guard units.
Here is copy of the email and reply:
dear sir
the phantom grip 944 units have been tested over 500 whp and torque.
thank you
phantom grip
> This is a multipart message in MIME format.
> I have a hybrid car making way more than stock horsepower and
torque.
> How much torque can your LSD unit support??
> My application has a 86 944 turbo transmission.
> I estimate I have around 400 ft lbs of torque!
> I look forward to hearing back from you as I am very interested in
adding
> LSD to my car!
> WOW, 500 HP and or Torque!!!! _________________ Bob Ward
80 9214 turbo, w 5.3 LS V8 |
Alex Roy
Joined: 03 Nov 2002 Posts: 694 Location: Springfield Oregon USA
Posted: Thu Aug 21, 2003 7:09 am Post subject: |
They said it has been tested at 500 hp and torque.......they never said it didn't fail with that much power
Just kidding. |
Posted: Thu Aug 21, 2003 7:56 am Post subject: |
you pay for what you get the Quaiffe is a much better designed unit and will not destroy the internals of the tranny, not saying that the Phantom grip LSD unit will though _________________ 3 928s, |
Joined: 29 Jul 2001 Posts: 9136 Location: Royal Oak, MI, USA
Posted: Thu Aug 21, 2003 10:18 pm Post subject: Diff options |
Yeah, works great till it trashes the spider gears. A 951LSD is a cheaper alternative and will bolt into the 5-speed 924 trans (or the 931 trans), excluding the snailshells (which should use a 911 diff). They can sometimes be had for $500, though you can pay retail up to $1000USD. Quaifes are available new retail for $1200 or so from OG Racing (www.ogracing.com IIRC). _________________ Vaughan Scott
CBass
Posted: Sat Aug 23, 2003 5:53 am Post subject: |
Has anyone actually used a 911 differential in a snailshell, or is this just theory?
I've read that the snailshell was based off the 915 tranny, but are the differentials interchangeable? Maybe we should start comparing part numbers  |
keith
Joined: 21 Sep 2003 Posts: 24 Location: Charlotte, NC
Posted: Mon Sep 22, 2003 7:23 am Post subject: |
I know for a FACT that the phantom grip is ineffective in a 340rwhp 951.
I know because we installed it in a customer's car and tested it. _________________ keith
86/9 951
the RUNT. |
Posted: Mon Sep 22, 2003 7:25 am Post subject: |
the 930 lsd Diff will work in the G31 _________________ 3 928s, |
CBass
Posted: Mon Sep 22, 2003 7:31 am Post subject: |
Has this been documented? If so, great, if not, I don't want to be the guy who spends $1200 on a GT or Quiafe diff and find out I'm gonna get soaked for a few hundred if it doesn't work and I need to resell it...
Also, I'd be looking for a lower ratio than the stock 4.7:1... My goal is to use a 9000rpm engine, so I'd want a lower final drive ratio. _________________ '81 931 in various states of assembly
Posted: Tue Sep 23, 2003 8:01 am Post subject: |
So like can we usea 911 diff and
would we want to is it a reaping
upgrade if so what years the same
years as the snailshell. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
turbobob9242
Posted: Tue Sep 30, 2003 10:00 am Post subject: 9000 RPM engine?? |
Are you using a motor cycle engine??
Never head of anything other than Mazdo Wankle engine or motor cycle engines reving to 9000 on the street. _________________ Bob Ward
Posted: Tue Sep 30, 2003 10:02 am Post subject: Re: 9000 RPM engine?? |
| turbobob9242 wrote: | Are you using a motor cycle engine??
Never head of anything other than Mazdo Wankle engine or motor cycle engines reving to 9000 on the street. |
where did you get that from???
also the Honda S2000, has a 10,000 rpm rev limit _________________ 3 928s, |
Porschephile
Joined: 04 Nov 2002 Posts: 825 Location: Denver, Colorado
Posted: Tue Sep 30, 2003 11:16 am Post subject: |
the S2000 uses a motorcycle engine. _________________ werd B. |
