Minus000
Joined: 29 May 2003 Posts: 363 Location: Sidney, B.C.
Posted: Wed Aug 20, 2003 7:44 am Post subject: Replacing Bleeding Nipples |
| Hello. I started bleeding my brakes this afternoon. I got three done using the standard two man method and was more then a little ticked to find that my last bleeding nipple (front left) has been stripped. I haven't taken the wheel off yet to check on it but it feels rounded. The peddle has firmed up quite a bit now with only three brakes done. Iv looked at a Diagram and it seems that I should just be able to unscrew the stripped bleeding nipple completely and then screw a new one back in. Does anyone know if there is anything more complicated to this procedure? Is there any other tips? Can I pick up a bleeding nipple at the ports store or do I need to talk to a porsche dealership? Thanks, Michael. |
Minus000
Posted: Wed Aug 20, 2003 8:04 am Post subject: |
| probaly going to just install a set of speed bleeders. I hope getting the stripped bleeder out dosn't turn out to be to much of a headache. |
78 924 N/a
Joined: 20 Mar 2003 Posts: 769 Location: Pacific N.W.
Posted: Wed Aug 20, 2003 9:01 am Post subject: |
visegrips _________________ 1978 924 n/a |
wdb
Posted: Wed Aug 20, 2003 9:14 am Post subject: |
| careful with visegrips , I've had the bleeders break off that way on a chevy . they are really thin walled and break easy . |
Posted: Wed Aug 20, 2003 10:46 am Post subject: |
...they cant be sucked on ! The speed bleeders, they
dont work
with a vacuum pump attached. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Roger
Posted: Wed Aug 20, 2003 11:15 am Post subject: |
they just unscrew, but be carefull they can be fragile. _________________ 1981 924 NA
Posted: Wed Aug 20, 2003 11:22 am Post subject: |
actually what works better is a small pipe wrench vice grips just cause more damage and break stuff _________________ 3 928s, |
Posted: Wed Aug 20, 2003 1:23 pm Post subject: |
You guys speedbleeders are cool vey handy like andy
though they say hes a real dandy,they have a big nut
area for the wrench. Wonder where I could get the rubber
dust caps I have no dust caps.  _________________ 1979 porsche 924 Na
jpab924
Joined: 03 Nov 2002 Posts: 1538 Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
Posted: Wed Aug 20, 2003 1:33 pm Post subject: |
| propane torch to heat it up a bit, then use the vicegrips. Don`t break it off! |
Joined: 29 Jul 2001 Posts: 9138 Location: Royal Oak, MI, USA
Posted: Wed Aug 20, 2003 11:06 pm Post subject: |
Be careful heating - brake fluid is flammable! Start with some penetrating oil, then vicegrips. Yes, screw-in replacements are readily available at the parts store in metric sizes. Likewise bleeder screw dust caps are available (I scam mine from work ) _________________ Vaughan Scott
Joined: 04 Dec 2002 Posts: 767 Location: Blyth, Northumberland, UK
Posted: Wed Aug 20, 2003 11:12 pm Post subject: |
| WD-40 left for a while then a couple of sharp (not too hard) taps on the end with a hammer worked on mine with, as mentioned, a set of plumbers pliers. |
Minus000
Posted: Thu Aug 21, 2003 1:42 am Post subject: |
| okay, im going to stay away from the propane torch for now. I couldn't find speedbleeders in town so im simply installing a new nipple. Should arrive today from there downtown location. Im going to spay on a little penetrating oil and try unscrewing with as little pressure as possible. |
Minus000
Posted: Thu Aug 21, 2003 9:02 am Post subject: |
| Nipple installtion went very well, got the other nipple off with no trouble using vicegrips and a little wd40. Once off the new one screwed right in place, I was worried about overtightening so I tightened the nipple until I could feel some resistance and gave it a 3/4 rotation. Just need to rebleed the brake system now. |
Posted: Thu Aug 21, 2003 9:19 am Post subject: |
Did you remember to ask for dust caps.  _________________ 1979 porsche 924 Na
Posted: Thu Aug 21, 2003 9:39 am Post subject: |
the other thing you can think of doing is putting VERY light amounts of antisieze on the threads of the nipple and after the brakes have been bled putting a coating of the antisieze compound on the nipple, I know it will pick up dirt dont worry about this, it will stop the metal from pitting, if you are worried about it just brushing off then either make sure there is no brake fluid around and heat it up to burn a coating onto the nipple, this will stop pitting and corrosion to the nipple _________________ 3 928s, |
