Battery box worse than I thought
CBass
PostPosted: Wed Aug 13, 2003 4:14 am    Post subject: Battery box worse than I thought Reply with quote
Ok, I finished stripping out my interior, and so now my attention has turned to the battery box. I figured it was pretty badly rusted, which it is. What I hadn't taken into account was the rust continues down into the firewall!
I can't see exactly how far it goes, but I'm going to peel back the firewall trim and see today.
Has anyone had this problem before? I figure I can just pull the engine and weld it up, maybe throw in a few chunks of lightwall 1" as a brace while I'm at it.
PostPosted: Wed Aug 13, 2003 5:30 am    Post subject: Reply with quote
Yea it probly went all the way down to where the frame comes out.
Theres like a wall there that is curved and it could have a bunch of pinholes in it from rust mine did.
CBass
PostPosted: Wed Aug 13, 2003 6:15 am    Post subject: Reply with quote
From the top, I can see the rust is pretty bad, but I can't see more than about 6" down... the rust appears to be around 6" wide, so it's probably more like 10"...
Have you fixed yours Joe?
PostPosted: Wed Aug 13, 2003 10:26 am    Post subject: Reply with quote
It helps to have the engine out.
gwsg
PostPosted: Wed Aug 13, 2003 11:41 am    Post subject: Reply with quote
On mine the rust didn't reach the firewall but it went through the bottom of the tray and came out through the mudguard just above the front wheel. About a 3" x 4" hole.
After cutting away all the bad metal treat with a rust converter [phosphoric acid or similar] followed by a coat of cold galvanising [zinc powder in epoxy] before sealing and painting.
Kill the rust totally dead or it will end up eating your whole car. Its like cancer.
My 80 924 loves me.
CBass
PostPosted: Wed Aug 13, 2003 12:02 pm    Post subject: Reply with quote
Thanks for the tips, I hope it's not too bad... This is all because the PO sealed it up using canned foam and some cheap sticky paint. I even found a rag stuffed in there.
gwsg
PostPosted: Wed Aug 13, 2003 5:14 pm    Post subject: Reply with quote
Bloody POs!
My 80 924 loves me.
PostPosted: Thu Aug 14, 2003 2:19 am    Post subject: Reply with quote
hahah-a its a goodtime to get some por-15 rust killer and try it out if you can find it up there.
CMXXXI
PostPosted: Thu Aug 14, 2003 3:50 am    Post subject: Reply with quote
Once repaired, I'd suggest a final coat using a rubberized spray undercoating material. 3M makes a good one I've used with great success in those areas exposed to the elements. I would think that the rubberized coating would help prevent a recurrance of the acid eating away at things.
'79 Eurospec 931
CBass
PostPosted: Thu Aug 14, 2003 4:36 am    Post subject: Reply with quote
I think housing the battery in a sealed box behind the passenger seat should solve these problems in the future
But for now, I have to do some serious wrenching and welding. Good thing I'm going to school in the fall for my welding tickets
CBass
PostPosted: Thu Aug 14, 2003 2:33 pm    Post subject: Reply with quote
I'm beginning to hate the previous owner of this car.
I pulled off the insulation stuff on the passenger side of the firewall, which has been acting as a sponge for the last 2 years in pacific northwest weather.
There is rust all the way down the passenger side of the firewall, about 40cm x 10 cm that needs to be cut and welded. Luckily, it seems to have missed the bellhousing.
Well, looks like I have my work cut out for me, and I won't be enjoying the handling of this car above civilian speeds until I fix it.
Nuts.
PostPosted: Mon Aug 18, 2003 3:45 pm    Post subject: Reply with quote
O man get the wire feed.
wdb
PostPosted: Tue Aug 19, 2003 7:42 am    Post subject: Reply with quote
hey joe , the last time we saw your firewall it had a sheet metal and screw patch holding it together . who fixed it and how
PostPosted: Tue Aug 19, 2003 10:57 pm    Post subject: Reply with quote
I too had this problem in my 82 931, completely tore it out and built a new battery box. Sucked, but at least it is now perfect!!!
CBass
PostPosted: Fri Aug 22, 2003 5:17 am    Post subject: Reply with quote
Sounds like a lot of work indeed
Got any pics Vaughan?
