question on new air intake boots
law-guy
PostPosted: Sun Aug 10, 2003 2:33 pm    Post subject: question on new air intake boots Reply with quote
I have a 1979 924 and I have just purchased new intake boots. I put the new boots on and now the car wont start. I think that the problem is that on one of the new boots, the boot that attaches onto the air filter box, there is an outlet about 1 inch long that looks like something should attach to it. My old boot did not have this outlet thingy. I am thinking about just plugging the outlet with a screw or something, but I was wondering if I got the wrong part or if something is supposed to attach there.
Thank you -- brian
924martinirossi
PostPosted: Sun Aug 10, 2003 4:52 pm    Post subject: Reply with quote
Here is the page of the air intake for your car. You nedd Adobe to view it.
http://members.rennlist.com/924martinirossi/Air%20Intake.pdf
Michael
Roger
PostPosted: Mon Aug 11, 2003 5:50 am    Post subject: Reply with quote
My 81 has it. It connects to a plastic part (probably some sort of valve) then the plastic part conects to a vacuum line that goes to the intake and connects right by the cold start valve. I couldnt tell you what it does though.
1981 924 NA
augidog
PostPosted: Mon Aug 11, 2003 11:19 am    Post subject: Reply with quote
mine is plugged with a bolt and clamp.
I would do the same on yours for starters.
78 924 N/a
PostPosted: Mon Aug 11, 2003 1:20 pm    Post subject: Reply with quote
Then try to find the right boot for your application.
1978 924 n/a
Doodle
PostPosted: Tue Aug 12, 2003 3:59 pm    Post subject: Reply with quote
My '77 came without the outlet. The replacement boot came with the outlet. I plugged the outlet with a bolt and hose clamp. It works fine. I believe the old style boot without the outlet has been superceeded to the boot with the outlet.
Doodle
Pre 77.5 Mars Red
