Tossing the snailshell!!!!!!
Wolf1
PostPosted: Fri Aug 01, 2003 1:56 pm    Post subject: Tossing the snailshell!!!!!! Reply with quote
Well, I have finally had all of the snailshell synchro problems that I can stand in my 80 931. What are my options? I have a complete 81 924 NA with a good 5 speed in it, I'm thinking about transfering it all into the turbo. Has anybody done this with any luck? I am wondering if it will hold up, and if the starter will clear with the turbo or will my original bell housing work with the NA torque tube? Any thoughts, comments, or...?
88 951 stone gray
80 931 Red and surgically enhanced
72 914 (old toy) $old
2 1/2 924's for spares..
PostPosted: Fri Aug 01, 2003 2:07 pm    Post subject: Reply with quote
dont the NA uses a 20mm shaft and the turbo uses a 25mm shaft
either fix the snailshell or get a 944 box
3 928s,
Wolf1
PostPosted: Fri Aug 01, 2003 3:04 pm    Post subject: Reply with quote
Yes the na uses a smaller shaft but I could swap the torgue tube and clutch as well. Will a 944 trans fit into the 931 and connect to the bellhousing?
88 951 stone gray
PostPosted: Fri Aug 01, 2003 3:42 pm    Post subject: Reply with quote
in order to put in a 944, you would need torque tube clutch and shifter mech,
Dont put the NA stuff in unless you like gears flying
3 928s,
PostPosted: Fri Aug 01, 2003 9:50 pm    Post subject: Reply with quote
Do the swap to the 944 stuff. Don't use the 924NA parts. Sell them here!
Wolf1
PostPosted: Fri Aug 01, 2003 11:16 pm    Post subject: Reply with quote
So your saying the 944 torgue tube will bolt onto the 931 bellhousing? If so that would be the best swap, 944 tranny's and parts are easier to come by than snailshell stuff.
88 951 stone gray
CMXXXI
PostPosted: Sat Aug 02, 2003 2:06 am    Post subject: Reply with quote
The synchro fix really isn't all that mechanically difficult if you have the tools and facilities. I think that it would be a more simple, less expensive repair than swapping in a 944 box. I replaced the 1,2,3 gear synchros last month, and the hardest part for me was breaking free the transmission mounting bolts. If you didn't follow it and are interested, here's a link to my story and photos: http://www.924board.org/viewtopic.php?t=7970
Haven't been involved in a tranny swap, so can't comment from experience what parts and problems are entailed in that conversion.
'79 Eurospec 931
PostPosted: Sat Aug 02, 2003 3:08 am    Post subject: Reply with quote
correct
3 928s,
PostPosted: Sat Aug 02, 2003 9:38 am    Post subject: Reply with quote
How about the rear suspension?
The 80 931 has the support bars for the tranny mounts. The 944 tranny mounts to the body.
Read the FAQs
Wolf1
PostPosted: Sat Aug 02, 2003 11:54 am    Post subject: Reply with quote
I could snatch the rear suspension out of one of my 924na parts cars. I have a complete 77 and complete 81. I've been told that the body mounts should fit the 80 931, but not sure. I will put the 931 and the 81 NA both up on the hoists side by side and do a little pre-surgery investigation. I will probably be parting out the 77 and 81 here pretty soon, even sooner if I rob the suspension out of the 81.
88 951 stone gray
PostPosted: Sat Aug 02, 2003 12:36 pm    Post subject: Reply with quote
Read the FAQs
right forgot about that part, but nothing an angle grinder wont take off easily
3 928s,
hzsogd76
PostPosted: Sat Aug 02, 2003 6:37 pm    Post subject: Reply with quote
Hahahz. Hillbilly machine shop!
Knowledge is the centerpiece of life. Without it we are all just animals
PostPosted: Sun Aug 03, 2003 12:39 am    Post subject: Reply with quote
Here's the info:
http://www.924.org/techsection/technical.htm
click on "7-transaxle" and space down.
CMXXXI
PostPosted: Sun Aug 03, 2003 12:51 am    Post subject: Reply with quote
Wolf1 - ...sounds like a whole lot of work and expense to go through rather than just repair what is there. But, I understand the joy (sometimes) of working on these cars and the satisfaction you get when the job is done.
Good luck with whatever solution you decide to employ.
'79 Eurospec 931
PostPosted: Sun Aug 03, 2003 1:20 am    Post subject: Reply with quote
I'm having the same problem and faced with the same decision.
I can't seem to find a new set of dogteeth for 1st gear for my 80 931. Partwerks has offered to adapt a set (new) from a different tranny, but it takes several other parts that are different from the ones already purchased for my tranny.
I already have everything else I need.
The Audi conversion is looking more and more desirable...
